vitara engine conversion alternater problem :(
hamer
Re: vitara engine conversion alternater problem :(
Post by hamer » Mon Apr 15, 2013 10:04 pm
ther are a couple of black and white wires ther not in the sammy conection box tho???
my alternator is difrent to the one you posted mate same round conecter but only one spade in it??
and the bolt aint on the side its on the back of it 2" up from the round box conection
hamer
Post by hamer » Mon Apr 15, 2013 10:07 pm
ScottieJ wrote:Probably the Lamp wire then, guess when you turn the ignition on the battery light comes on and the. Goes off once the engine is started? I seem to remember that is the only connector in the terminal on most.
It should be red and white but chances are the white bit has just gone yellow after 20years in an engine bay :lol:
i aint started it sat in the seat yet so aint seen no lamps mate
il check tomoz and also put testers on it and report back :)
exhoust aint bolted up yet so dont want to upset the neighb ours at this time of night lol
Post by ScottieJ » Mon Apr 15, 2013 10:09 pm
Presume yours has the regulator on it that looks like this Hamer?normally they are Bosch but as I'm good at killing them I though id try a cheaper one :lol:
hamer
Post by hamer » Mon Apr 15, 2013 10:11 pm
wher two would that be mate?
il run out the back and check naw
Post by ScottieJ » Mon Apr 15, 2013 10:12 pm
It's on the back of the alt, it's impossible to miss
Post by Jordi » Mon Apr 15, 2013 10:15 pm
Splash guard Scott. Lol
hamer
Post by hamer » Mon Apr 15, 2013 10:17 pm
yes it has one mate but no spade conections on it?
just re checked ur pic...ther aint one on it :)
Post by ScottieJ » Mon Apr 15, 2013 10:27 pm
Jordi wrote:Splash guard Scott. Lol
:thefinger:
hamer wrote:yes it has one mate but no spade conections on it?
There's no spade connectors on the voltage regulator, that bit sticking out the top is just a protective cover on the brushes ;)
hamer
Post by hamer » Mon Apr 15, 2013 10:33 pm
cool thanks butt..
feel quite confident iv got it right naw :)
Post by ScottieJ » Mon Apr 15, 2013 10:52 pm
Tidy
:doublethumbs: let us know if it all works fine.
