Sj413 carb
Re: Sj413 carb
Anyone ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Sj413 carb
Looks like the auto choke doesn't work , so somebody has tied it open-off.
Split vacuum pipes can cause this not to open on warm-up depending on which ones are knackered but the wax element should still open it when hot. (Maybe not without help from the vacuum side )
The hose is just "vacuum advance hose" available at any half descent motorist shop.
Much more info is in the link I posted earlier.
Hope that's what your after
Re: Sj413 carb
Any excuse for a diagram while I'm having a cuppa!!
- Autochoke diagram 1.jpg (156.26 KiB) Viewed 5005 times
- Ladaman
- Suzuki Guru
Re: Sj413 carb
I did a similar cable tie bodge to the standard carb on my Sammi.
I really wanted to keep the original carb, not sure why really, I just did.
I fully stripped and cleaned it, sometimes it would run a treat, other times it would keep stalling, and the time I did the cable tie "fix" was because it wouldn't run slower than about 2,000 rpm. The cable tie sorted it though.
The standard carb is a totally over complicated PITA, bin it and fit something else!
Re: Sj413 carb
Relevant section robbed from the manual
- choke 2.jpg (366.41 KiB) Viewed 4990 times
- Choke 1.jpg (346.67 KiB) Viewed 4990 times
Re: Sj413 carb
I may just leave it for now then,I,ll replace pipes as some are a bit tatty and perished and see how it goes as when it's warm it runs and tricks over ok
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Sj413 carb
People are often saying the autochoke fails, so which part screws up ??
Thermo wax unit??
Either of the diaphrams??
BVSV valve??
When people say fails, does this mean it doesn't go off (fully open)??
Is it possible to put a cable onto the linkage to make it manual??
Enough questions for ya ????
Thermo wax unit??
BVSV valve??
Re: Sj413 carb
My first view of it I Thort it was manual and someone didnt put cable on
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
