33s Whoo Hoo!!!! They've ARRIVED!!!
Richie
Re: 33s Whoo Hoo!!!!
Post by Richie » Wed Apr 17, 2013 11:15 pm
Ive smashed the bulk head and welded it alittle bit back but im 6 foot 4 and dont wanna lose any more leg room lol. Dunno if its true but im sure ive heard when u put rears on the front they move the axle foward about a inch anyways... Did u need a prop spacer?
Post by Jordi » Wed Apr 17, 2013 11:18 pm
http://forum.suzukiclubuk.co.uk/vi ... php?t=1545
Standard springs
Lifted
Best photos i could find. I have approx 5" clearance all the way round on 31s. No fouling at all. So 33s should be fine, i've also got extended bump stops to i dont kill my nice springs or rip the 1600 sump off when i fit it.
Post by Jordi » Wed Apr 17, 2013 11:22 pm
I haven't moved the axle (yet). If i dont have to i probably won't. I'd probably need extended props (don't like spacers) and it would cock the castor up so i'd need shims or small lift shackles to correct it.
Post by ScottieJ » Wed Apr 17, 2013 11:23 pm
You won't loose any leg room ;) you only need to cut out the section behind the throttle pedal and remove the stop for it so the pedal just ends up being stopped by the new section that you weld in.
This is cut out enough to clear 33s with standard height suspension.
You won't even notice the difference!
Post by Jordi » Wed Apr 17, 2013 11:24 pm
Richie wrote:Ive smashed the bulk head and welded it alittle bit back but im 6 foot 4 and dont wanna lose any more leg room lol.
Remount the seat further back.
Post by Jordi » Wed Apr 24, 2013 10:33 pm
Ok, took longer than expected. Just order four GT Radial Adventuro M/Ts 33/12.50/15s.
upjakscreek
Post by upjakscreek » Wed Apr 24, 2013 11:33 pm
Nice, you putting these on the new wheels? How will the offset work for you?
Neil
Post by Jordi » Thu Apr 25, 2013 2:37 am
Got some off set 15x10s for them. Also got wheel spacers.
So it should look pretty fat.
Re: 33s Whoo Hoo!!!! They've ARRIVED!!!
Post by Jordi » Fri Apr 26, 2013 5:32 pm
Stood next to a standard rim.
Tread
Sidewall
I was supposed to do a width comparison photo against standard too but forgot.
Post by ScottieJ » Fri Apr 26, 2013 6:00 pm
:rockin: can you let me know the true height once they are fitted? I'm tempted to sell the buckshots.
