Page 2 of 2
Re: CV Gaiter Boot
Posted: Wed May 01, 2013 11:26 am
by The Bird Man
Could be Scottie, I'm not really sure. I think a photo is in need to make things a bit clearer. Basically I need something to cover the ball joints on the axles as water and rubbish will just get in otherwise and I don't want that to happen ! :) My friends landy has a leather material bag covering his.
Re: CV Gaiter Boot
Posted: Wed May 01, 2013 11:59 am
by dazerede
Umm mine Looks like that aswell but a lot cleaner I would keep that area clean
Maby it needs a new seal as there is some oil there
Re: CV Gaiter Boot
Posted: Wed May 01, 2013 12:14 pm
by turbo-tom
id say degrease it all down and overhaul the cv joint/s. Its not hard job. if i remember rightly that the cv joint has the felts to "clean" off any dirt/muck that gets on the the chrome balls (cant remember the exact name). but in the back of the hub there is a big 0 ring/seal/ and thats what stops the dirt going in/grease coming out of the joint.
Re: CV Gaiter Boot
Posted: Wed May 01, 2013 12:50 pm
Just get some new seals and felts, there is no need for anything else covering the knuckle ball.
I don't really know why your mate has something covering them either, it really is not needed if the seals are in good condition.
It should look like this
Re: CV Gaiter Boot
Posted: Wed May 01, 2013 2:28 pm
Yeah. As above there is nothing to cover the end of the ball/knuckle. All SJs have is a rubber seal, two piece semi circle retainer, felt seal then another two piece semi circle retainer.
Just give it a wash off. Not unusal to get mild pitting but the constant movement of the steering self cleans most of the crud off.
Re: CV Gaiter Boot
Posted: Fri May 10, 2013 9:06 am
by The Bird Man
I see what you all mean now, makes much more sense now it's been explained, plus it helps not looking for something that shouldn't be there in the first place ! :D Thanks for the help guys ;) Where abouts can I order a set of these ? Also are they easy to fit ? While I'm at it, I notice that the 410 axles are smaller than the 413's, is bigger better ? Thanks :)
