Page 2 of 2
Re: Prop spacer needed
Posted: Mon May 20, 2013 2:58 pm
Oh yes I was going to take some pics of my ruined upside down rear springs!!!
They are absolutely trashed and a perfect example of why all extended shackles need to go in the bin!
Posted: Mon May 20, 2013 3:14 pm
by turbo-tom
ROBBIE wrote:
turbo-tom wrote:Shackles aka fangs.
aka spring killers
AKa bollocks.
Posted: Mon May 20, 2013 4:59 pm
Longer shackles aren't spring killers if set up correctly and the shackles aren't too long ;)
Also if you run a samurai with the smaller diff flanges then a late 410 propshaft is a better and probably cheaper alternative to a prop spacer, they are around 1" longer than samurai props ;)
Posted: Mon May 20, 2013 6:48 pm
by ROBBIE
3 inch over standard = spring killer as I found out with the ones that came with the SJ
Posted: Mon May 20, 2013 6:52 pm
ROBBIE wrote:3 inch over standard = spring killer as I found out with the ones that came with the SJ
That much over standard and it'll max out the shocks :lol: it's like the ones that were fitted to karis's when we bought it, the previous owner must've forced the springs down to get the shackle bolts in, the were S shaped where the shocks had no down travel left :lol:
