tow rope
- littlesammy
Re: tow rope
Ive got a couple of kinetic straps that so far have pulled whatever ive asked out !!
87 Samurai with added spice !
Re: tow rope
Demar turns out to be just down the road from me and a 3m orange 5t towing strap has set me bak 5quid just need to get some shakles now
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
cd players
99% rust free
alloys
bukets
Re: tow rope
Get yourself some 7-10t shackles just to be safe
Re: tow rope
That would be known as a ground factor, used to work out the rolling rolling resistance. Also depends on the gradient, any damage and a safety factor.twiss wrote:I found an excellent guide to winching that showed the effects different types and amounts of mud/stuckness and how much it effectively increases your vehicle weight.
I think it works out that if you are stuck over halfway up your wheels, then it effectively doubles the weight you are pulling... Usually when I get stuck its normally a case of mud up the doors so climb out the window
That's got to at least quadruple the weight!
