Which thermostat / sensor
Re: Which thermostat / sensor
The one i'm using is a Rockwatt modded 1.3 manifold onto my 1.6.
- turbo-tom
thought you was so are the 1.3 stats the same as 1.6 stats? *goes looking on Autodata*
- turbo-tom
Right according to Autodata it says the Sj413 engine stat opens at 88degrees and the vitara 8v engine stat opens at 82 degrees... only 6 degrees difference but the next thing is are the the two stats the same size? id think they would be ?
I'll check tomorrow. I fitted the 1.3 stat as the 1.6 was a different fit and didn't sit right in the 1.3 manifold.
- turbo-tom
ahh thought it might be im sure a grinder could fix that problem!
Did your 1.6 stat have a rubber ring around it? If so just remove that and it should fit?
Maybe
And yeah run the 1.3 sender
Maybe
- mike harris
- SCUK is my life
mines got all 1.6 in it, seems ok
- turbo-tom
Yeah but you dont have a 1.3 manifoldmike harris wrote:mines got all 1.6 in it, seems ok
When I was on my 1.6 8v and the SU, I ran it with a 1300 stat and a 1300 sensor
Trying that combo now Twiss.
Cheers for all the input chaps.
