Page 2 of 2
Re: Which thermostat / sensor
Posted: Sat Jun 01, 2013 11:55 pm
The one i'm using is a Rockwatt modded 1.3 manifold onto my 1.6.
Posted: Sat Jun 01, 2013 11:56 pm
by turbo-tom
thought you was so are the 1.3 stats the same as 1.6 stats? *goes looking on Autodata*
Posted: Sun Jun 02, 2013 12:03 am
by turbo-tom
Right according to Autodata it says the Sj413 engine stat opens at 88degrees and the vitara 8v engine stat opens at 82 degrees... only 6 degrees difference but the next thing is are the the two stats the same size? id think they would be ?
Posted: Sun Jun 02, 2013 12:14 am
I'll check tomorrow. I fitted the 1.3 stat as the 1.6 was a different fit and didn't sit right in the 1.3 manifold.
Posted: Sun Jun 02, 2013 12:16 am
by turbo-tom
ahh thought it might be im sure a grinder could fix that problem!
Posted: Sun Jun 02, 2013 9:25 am
Did your 1.6 stat have a rubber ring around it? If so just remove that and it should fit?
Maybe :lol:
And yeah run the 1.3 sender ;)
Posted: Sun Jun 02, 2013 2:09 pm
by mike harris
mines got all 1.6 in it, seems ok
Posted: Sun Jun 02, 2013 2:43 pm
by turbo-tom
mike harris wrote:mines got all 1.6 in it, seems ok
Yeah but you dont have a 1.3 manifold ;)
Posted: Sun Jun 02, 2013 2:54 pm
When I was on my 1.6 8v and the SU, I ran it with a 1300 stat and a 1300 sensor
Posted: Sun Jun 02, 2013 3:29 pm
Trying that combo now Twiss.
Cheers for all the input chaps.
