Head lights
Re: Head lights
the negative wire that goes to the positive melted few weeks ago and replaced it today and everything started to smoke again so ripped it off the car works fine now but the lights !!
Re: Head lights
I wonder who wired this up
- 131_0702_05_z+suzuki_samurai+front_view_fire.jpg (77.16 KiB) Viewed 5163 times
Re: Head lights
Negative wire to the positive?
Re: Head lights
Please see above fire !!!!!Jordi wrote:Negative wire to the positive?
Well if you don't have fuses
Re: Head lights
Errmmm the negative never go to the positive! Ollie before you do anything with those wires take a picture for us and we'll show you what goes where!OllieSJ wrote:the negative wire that goes to the positive melted few weeks ago and replaced it today and everything started to smoke again so ripped it off the car works fine now but the lights !!
Otherwise your SJ might end up looking like that one ^^^^^^^^^
Re: Head lights
i wacked it in the same place as it was when i got it so no wonder it set on fire like 2 weeks after i got it
Re: Head lights
Oh i have just red through. i didnt link the battery terminal negative to the postive. I was the wire thats the earth that goes from the positive and bolts onto the body
Re: Head lights
take that wire out as quick as you can ollie. this is putting power on everything the wrong way round, and you can cause some serious damage. there should be a wire from the negative terminal on the battery to the body, this is where all the power comes back. the positive terminal on the battery supplies all the power to your car, and shouldn't be connected to the car body, or it will burn down
Re: Head lights
Only the negative gets earthed. All positive wires need to be insulated from earthing out. If the positive earths by mistake it would the fuse. Thats the idea of fuses.
