rockwatt manifold and su hif44 carb pipe work help needed
Re: rockwatt manifold and su hif44 carb pipe work help neede
Think there was one that went to the old carb which gets blanked?
Is it blanked Dan? I think i just effectively joined the old carb feed and return together to complete the "circuit".dan_2k_uk wrote:Think there was one that went to the old carb which gets blanked?
Do u mean the return being the hose that goes to the bottom of the thermostat housing?
These are the water pipes im not sure about
- 20130626_085611.jpg (2.66 MiB) Viewed 5728 times
These
- 20130626_085611.jpg (2.66 MiB) Viewed 5727 times
This is how I understand it
The far right goes to the bottom of the inlet manifold under the thermostat
The fat one is the bottom rad hose
The left one at the bottom goes to the heater valve closest to the brake res pot
The left top one is the one in the previous pic which doesnt go to anything?
I will look at mine later if you are still stuck. I cant remember and I am using the 1.3 water rail not the 1.6 one which might have an extra hose position.
Where is the other hose from the heater matrix going?
Im still stuck on this, the bottom left one im not sure where it goes, any help welcome. If I can get it sorted I still might make wagtail
The top left in that photo is just blanked with a bolt and a jubilee clip on mine.
The hose from the Heater valve goes to the manifold.
The rest are marked here
- Untitled.jpg (932 KiB) Viewed 5690 times
