Page 2 of 4
Re: Transfer box mounts
Posted: Sun Sep 15, 2013 12:03 pm
by turbo-tom
in the message box were you type to reply etc there is a ebay button push that and then put your code in ie
so it looks something like that (ignore the code box)
and then you get something like this bud
Click Here for Ebay Listing
Posted: Sun Sep 15, 2013 1:50 pm
by Sj410red
Ok cheers for that Tom... Scottie, if I got longer bolts I cud add and extra poly bush top and bottom like that set you linked to me. My stock 1s are shot really, had quite a vibration thru the t box stick. I have noticed ther is more of a transmission noise now with what I have done but no vibration.
Posted: Sun Sep 15, 2013 3:48 pm
by Sj410red
I've just had a re-mod on the mounts I've added a 1/2 inch poly bush top n bottom, what do u think?
Posted: Sun Sep 15, 2013 8:04 pm
by turbo-tom
cant see any problems with that mate! sj's a known to have loud transmissions
Posted: Sun Sep 15, 2013 8:24 pm
by Rambo416
Hello there am new to this site
i had same problem with shaky 4wd stick and changed to the mounts ScottieJ has mentioned but now the back end shakes and vibrates a lot around 40mph
WHAT HAVE I DONE WRONG?
any help guys would be great cheers
Posted: Sun Sep 15, 2013 8:44 pm
by Sj410red
Hi, have you checked yur uj's on rear propshaft? Perhaps there worn and giving the vibration, mine failed its mot on bad joints, fitted newer 1 and it was a lot quieter than before.
Posted: Sun Sep 15, 2013 8:53 pm
I'm running those ones in Scotties link. No problems as yet.
Mine came from Dave @ Llama though.
http://www.llama4x4.com/page5.htm
Posted: Sun Sep 15, 2013 9:29 pm
by Rambo416
I have changed the prop as i had the splines badly worn and uj's and splines are now good
however when i fitted new mounts i put the rubbers in the middle of the mounts
I.e how should they be fitted cos they maybe wrong
cheers
Posted: Sun Sep 15, 2013 9:40 pm
Rambo416 wrote:I have changed the prop as i had the splines badly worn and uj's and splines are now good
cheers
Any photos of them?
I runs the Llama mounts and all is good. I did have to cut a bolt down a bit though. One of the bolts would only go in from the bottom up overs and when tightened it touched the bottom on the body making a hell of a noise. Chopped a few mill off and its spot on.
I would go through and check all bolts for tightness in the drive train.
Posted: Sun Sep 15, 2013 10:08 pm
by Rambo416
ok they are done on all three like this?
