I'm just trying to work out if it's just a stock pic they're showing for both listings but the contents may actually be different...........this is the description for both, (most expensive 1st)twiss wrote:Yeah I would say for £100 thats a bargain... will take AGES to arrive though probably :(
You will probably have to pay 20% on top for import duty
This kit includes
2 x inner axle seals
2 x spindle (hub) bearing seals
2 x spindle nut lock rings
2 x knuckle felts
4 x Wheel Bearing
4 x kingpin bearings
All Seals
This kit includes
2 x Inner axle seals
2 x Spindle (hub) bearing seals
2 x Spindle Nut Lock Rings
2 x Knuckle felts & 4 half retainer brackets
4 x Wheel Bearings
4 x Kingpin Bearings
2 x Axle Gaskets
2 x Hub Gaskets
