Checking a Lockright install
Ladaman
Re: Checking a Lockright install
Post by Ladaman » Wed Nov 27, 2013 12:02 am
Well after a couple of chats with Mike H, it would seem it does need some adjustment, as he has just had a similar problem.
As the shims behind my side gears are already only 0.030" (0.75mm) thick, I don't fancy skimming them down by the 0.010" (0.25mm) needed.
I could make a 0.010" shim to space the two halves of the carrier apart which would sort one side, but I do need to machine out the main part of the carrier, so I might as well machine them both.
A bit scary, but it should work.
Wish me luck boys, I'm going in!!
PS Thanks for the help Mike :thumbup:
Post by mike harris » Thu Nov 28, 2013 9:56 pm
No worries mate:)
Richie
Post by Richie » Thu Nov 28, 2013 11:13 pm
Reading this makes me dread putting mine in in. Let me know how you get on plz
Ladaman
Post by Ladaman » Fri Nov 29, 2013 9:13 am
Don't worry, it's not hard as long as you do some simple checks when building it. It's just a shame they aren't mentioned in the instructions.
I was going to take photos during the build, but didn't have time.
If it works well this weekend (going laneing in Wales). I will look to write some "additional"instructions.
