Re: Lwb and swb gearbox.
Posted: Sat Feb 01, 2014 3:26 pm
The gearboxes will swap if they are both 1.6 engines. The 16V SWB has a higher 5th gear ratio and if you're swapping tcases as well then the spline count on the output shaft changed around 96.
