LED front sidelights + indicators?
trotter
Re: LED front sidelights + indicators?
Post by trotter » Wed Nov 27, 2013 8:44 pm
No worries, that's where me and dan got our rear lights from, and I've got a set of those indicators to fit when I get time to fit my new grill etc
if in doubt, FLAT OUT!
trotter
Post by trotter » Wed Nov 27, 2013 8:45 pm
Bear in mind you will need to change the relays as (led's take less power I think) they will flash diff speed aka too fast
Jay18
Post by Jay18 » Wed Nov 27, 2013 8:47 pm
ahh, that could be a problem...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Hodgie812
Post by Hodgie812 » Wed Nov 27, 2013 9:06 pm
I found these on ebay, but as Trotter said you will need resistors to slow the indicator flash speed down. Less resistance through the led's as opposed to normal filament bulbs.
http://www.ebay.co.uk/itm/330921624246? ... 1423.l2649
I do like dazerede's set up though, it really suits the style and era of the anus. Good job mate.
Jamie.
Built with ebay!!!
Post by Darrell » Wed Nov 27, 2013 11:25 pm
You can drill and fit these in your standard headlamps..
Resistors for the LED indicators are about 8-10 squid a pair.
Click Here for Ebay Listing
Ladaman
Post by Ladaman » Thu Nov 28, 2013 12:05 am
I got some of those LED button type light from Bolt on Bits for indicators, I also got headlights with built in sidelights from there. And for the rear, LED stop, side & indicators, fitted into the bumper so as not to damage. I've also just fitted (not on the pic) an LED fog light as I was sick of knocking off the £4 ones when hanging off the bottom of the bumper.
Post by twiss » Thu Nov 28, 2013 9:26 am
Just a quick point, if you are using LED indicators, don't use ballast resistors, they are a pain in the arse!
get yourself an LED indicator relay instead. they only cost a couple of quid and do the same job! difference is you only need one of them and installation is as simple as taking the old relay out and putting the new one in!
The only thing i've had to do it slightly trim down the relay holder as the LED relay is a little bit bigger than the standard one
Mine's a bit like this:
http://www.ebay.co.uk/itm/3-Pin-Car-Fla ... 54017650d4
Post by dan_2k_uk » Thu Nov 28, 2013 1:13 pm
I just filed down the element in my standard relay to match the resistances of the relay to the indicator circuit. Works a treat.
I do however have a relay for a jap SJ somewhere as I ordered the wrong one. (Hence I got pissed off and tried the fileing method)
Jay18
Post by Jay18 » Thu Nov 28, 2013 5:10 pm
Hmmm will see what I end up doing when I've made the bumper...
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
