i have a wierd squilling noise from the rear axle
- donkeychomp
Re: i have a wierd squilling noise from the rear axle
If a UJ does go pop you can always put it in 4WD and drive home in 2WD if you get my drift...that happened to me once. Was in front wheel drive only but it lasted ages before I got a new UJ.
Brand new bearing then....Jordi wrote:Another 1000miles in that.
Problem was the stereo was at full and I could still hear it squealing
Probably a dry UJ, take the prop off and investigate, most likely will be the axle end. I've got this at the moment too, i'm waiting for it to explode
Hence my wanted add for a new prop as there's not much point replacing a UJ on a crap propshaft.
- dazerede
Just looked and there is a little bit of play nothing much
Sprayed it with wd40 and it still is making the noise
I will take prop of when I finish college and investigate it I.might have a spare rear prop I will pop on
4” calmini lift kit
4” calmini lift kit
there could be no play at all but it could be dry and stiff. wd40 will not make any difference, UJs need grease.dazerede wrote:Just looked and there is a little bit of play nothing much
- dazerede
Ok I.will fill it with grease and go from there
Before I.sprayed with wd 40 the end of the prop looks oily I thought it was the pinion seal from the diff but the diff oil hasn't dropped so the grease has leakedout and become dry
- IMAG0332.jpg (1.88 MiB) Viewed 4182 times
4” calmini lift kit
4” calmini lift kit
- dazerede
This is a pic before I sprayed wd40 on.it so it must of leaked out as you can seethe grease has sprayed every where underneath
4” calmini lift kit
4” calmini lift kit
