king pin bearings have gone in my 410 axle
- dazerede
Re: king pin bearings have gone in my 410 axle
Ummmm ideal Darrel
4” calmini lift kit
4” calmini lift kit
dazerede wrote:Kingpins bearings have gone
Vidoe of how bad it is lol
http://www.youtube.com/watch?v=0V-sOiHe ... ata_player
Not quite my normal diagram --
- imageedit_2_3455066837.jpg (97.99 KiB) Viewed 5197 times
- Edweird
That's a dynamic camber system. Fancy stuff.
I swear in a guide I read on Jimny death wobble it said they differ. Maybe its just the shimming that is different as I know on a Jimny you shim the pin head to add pressure to the bearings rather than shimmimg the pin mount to reduce it.Darrell wrote:I believe both use 30302
15mm x 42mm x 14.25mm taper bearing
Sorry. Both use a 30302j. Just the shimming setup is different.
- dazerede
Ok chears guys
4” calmini lift kit
4” calmini lift kit
That's so bad I wouldn't be surprised if you've actually snapped a kingpin! If so I have a hoard of spare kingpins
- dazerede
Write I had a day off college so I took it all apart and found that the kingpins are in good condition it was just the bearings that have gone so that saved me a couple of quid I think I have a set in.the shed as I have a spare front axle in.my shed apart from the casing parts are ordered and should be here tmoz from jimnybits
- FB_IMG_13867766774233300.jpg (1.47 MiB) Viewed 5160 times
- IMAG0373.jpg (1.46 MiB) Viewed 5160 times
- IMAG0372.jpg (1.3 MiB) Viewed 5160 times
- IMAG0375.jpg (1.69 MiB) Viewed 5160 times
4” calmini lift kit
4” calmini lift kit
Don't think I have ever seen such fucked kingpin bearings
Have you a bit broken out of bearing cup in axle? I managed to wipe out half the cup on mine, so had to change axle.
