major vibrating
Shawboy
Re: major vibrating
Post by Shawboy » Thu Feb 06, 2014 10:06 pm
he does some nice stuff rockwatt and yes ty for that link ill look tomorrow and then decide where im going from there cheers
Eat! Sleep! Offroad! Fix! Repeat!
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Re: major vibrating
Post by Jordi » Thu Feb 06, 2014 10:15 pm
I'll be having one of those soon.
Re: major vibrating
Post by ScottieJ » Thu Feb 06, 2014 10:21 pm
To be honest it's not really a good idea to drive SJs in fwd with the the rear prop removed anyway as the front output isn't amazingly strong.
However it shouldn't vibrate that badly.
As stated check everything mentioned, plus check the engine mounts, it's best to take the weight off the engine and physically remove the mounts to do this.
Can you post up some good clear pictures that show both ends of the propshaft in one picture.
Also when you split the prop shaft at the splines there's dots to line up to make sure it goes together as it was at the factory so that it is properly balanced, they can be 180* out so still in phase but slightly out of balance.
Is there any play in the front output on the tbox?
Shawboy
Re: major vibrating
Post by Shawboy » Fri Feb 07, 2014 12:01 am
cheers scottie i will get back to the post in the morning and i had to get it back to my unit as my grandma was moaning it had ben there too long dint have much choice lol.
ill try my best in the photos and ill have a look if i can see any dots.
cheers
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
