sj has a cold.
kiwizook
Re: sj has a cold.
Post by kiwizook » Wed Mar 05, 2014 5:52 am
definetly water in your oil mate, do a pressure check on all cylinders to see if it has a gasket leak, or just replace it anyways without checking, should be a relatively easy job to do
timwilks13
SCUK Website Padawan
Re: sj has a cold.
Post by timwilks13 » Wed Mar 05, 2014 10:11 am
as i dont know the condition of the engine when i bought it i have ordered a head gasket and timing belt and will do them both tonight to be safe. Will pressure test it first just to see, and i kinda hope it is the head gasket, if it pressure tests fine and the head is fine then im at a loss as to the issue! unless as twiss has suggested i have put a pipe on wrong, and got a vac pipe on a water feed etc, will wait and see!
Re: sj has a cold.
Post by ScottieJ » Wed Mar 05, 2014 5:50 pm
While the head is off, if it comes off make sure you check for warpage with a straight edge and feeler gauges and get it skimmed and pressure tested if necessary.
Not good news either way :thumbdown:
timwilks13
Re: sj has a cold.
Post by timwilks13 » Wed Mar 05, 2014 7:19 pm
Think my fan is broken?!
Re: sj has a cold.
Post by Jordi » Wed Mar 05, 2014 7:43 pm
timwilks13 wrote:Think my fan is broken?!
Sure I have spares.
timwilks13
Re: sj has a cold.
Post by timwilks13 » Wed Mar 05, 2014 7:54 pm
That will have to do till April now unfortunately, had some horrible bills through the post today!
Re: sj has a cold.
Post by Edweird » Wed Mar 05, 2014 10:01 pm
Wow that's a lot of emulsion.
timwilks13
Re: sj has a cold.
Post by timwilks13 » Wed Mar 05, 2014 10:31 pm
Interestingly the rockers weren't coated at all, the gunk was only on the rocker cover and being sucked through the breather and fed through the carb, so gone back to a nice clean 1.3 cover and will run the breather to the pcv and to it's own little filter.
The head gasket looked fine when I took it off, no obvious gaps, so changed it and the timing belt and will see tomorrow if she's any better!!
