Ed's wagon
Re: Ed's wagon
Post by Edweird » Sun Jul 08, 2012 1:18 pm
ScottieJ wrote:Darn I forgot to mention that the gearbox crossmember might be in a different place, I knew that d'oh! shouldn't be hard to make an adapter though I don't think. How long is your intermediate propshaft ed? I have a few spares.
Aye, Dad said that over the phone too. He reckons he could make a 'D' shaped adapter easily enough. As for the intermediate prop, I've just asked Dad to measure it, but he thinks that the one we want needs to be slightly shorter as well as having the larger spline size on the input end. He said he was going to measure it 'between centres' on the UJs.
Re: Ed's wagon
Post by ScottieJ » Sun Jul 08, 2012 10:18 pm
ok well I have two different length ones so let me know :thumbup:
Re: Ed's wagon
Post by Edweird » Mon Jul 09, 2012 1:17 pm
These are the two pictures Dad sent me showing how he measured the intermediate shaft:
Dad's e-mail said:
"The 5 speen box is approx 1inch/25mm longer than the 4 speed so this means the prop wants to be shorter by the same amount.
I reckon the overall length of the prop you need should be approx 15 3/8" or 391mm
Also you need the larger diameter splines to fit onto the gear box. Have not been able to measure these."
Hope this is enough info Scott. If it is, I don't suppose we could sort out couriering one from you somehow could we? I need it by Thursday if it's possible.
Tell you something else, it's such a b*stard being stuck at home 40 miles from my truck with nothing but a bicycle; especially when I'm trying to find a job.
Re: Ed's wagon
Post by Edweird » Wed Jul 11, 2012 11:04 am
Has Scott won a trip to the moon or something? He's not been on in two days.
Re: Ed's wagon
Post by ScottieJ » Wed Jul 11, 2012 12:19 pm
alrighty, my smartphone got killed by a falling piece of box section and that's my main access to tinterweb, I would imagine i'll be popping over one evening this week so will do some measuring :thumbup:
Re: Ed's wagon
Post by Edweird » Wed Jul 11, 2012 2:19 pm
ScottieJ wrote:alrighty, my smartphone got killed by a falling piece of box section and that's my main access to tinterweb, I would imagine i'll be popping over one evening this week so will do some measuring :thumbup:
Okay, thanks Scott.
Re: Ed's wagon
Post by Edweird » Sat Jul 21, 2012 12:59 pm
Look at what I got!
My HIF 38 from Silverfox/Rodger arrived yesterday so I'm going to get that fitted fairly sharpish because there's something wrong with the aisin one. It's running so rich that she stalls if left idling and is black smoking a bit.
I also understand what Rodger was talking about now with the ram pipe causing problems with the piston now.
The plate blocks the atmospheric air breather for the suction chamber. Should probably be able to solve that by carefully drilling a hole in the plate.
Also, Rodger, should I take it apart and clean it out, or have you already done that? It seems to have oil in the dashpot piston damper so I was wondering if you'd done it already.
Re: Ed's wagon
Post by Edweird » Sun Jul 22, 2012 8:07 pm
Drumroll please!
Click Here for Youtube Video
I've got the SU fitted, all but two hoses blanked off. I couldn't believe how many connections I was blanking off at first, but they all make sense. Centrifugal ignition advancing, so no vaccum hose. Rocker box breather is in the manifold. There were two I didn't know what they did but Rodger had already blocked them off so I decided to try it with them still bunged and it fired up and once it had warmed up a bit it idled better than ever before.
I had to take off the resin insulator spacer to get the carb to fit on the manifold studs. I have a feeling the carb getting warm is a bad thing, but I can't remember for why.
Re: Ed's wagon
Post by Edweird » Mon Jul 23, 2012 1:51 pm
Well, it's been in there for a day now and I've found that it's difficult to start from cold and the idling is intermittent, one minute it's idles beautifully, another it's lumpy as hell, and when you turn the car off a little pit of petrol runs into the airbox hose.
What have I done wrong? Carb has six hose connections and I've blocked four of them. The overflow (I think) and fuel inlet have been connected. Drives great under power once the engine is warm and is gutless when cold.
Re: Ed's wagon
Post by Edweird » Mon Jul 23, 2012 10:40 pm
Update!
It now doesn't run at all. I have changed nothing since I put it on and it has gone from running better than ever before to having absolutely no life in it what-so-ever.
