- SlimGrim
- Winching along now
Pedal mount?
___________________
Oh, but you can Dan!dan_2k_uk wrote:I'm so sure I recognise it but can't put my finger on it.
Nope, getting cooler SlimSlimGrim wrote:Pedal mount?
- SlimGrim
Bollocks
___________________
- SlimGrim
That was not a guess at the pic btw
___________________
Clue 7: It could be described as a lever of sorts.
Is the weight inside the steering wheel?
Looks a little like the Jimny one??
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Ignore that post above, didn't read all the clues!
Is it the red bit you push down to release the seatbelt?
No, sorry zook123!
Just to help you folks from 'back paging', here are all the clues again
Clue 1: The part you can see in the pic, is not normally visible.
Clue 2: Time from start to finish to remove the part would be less than 5 minutes!
Clue 3: There are two of these, one LH one RH on SJ410's, SJ413's, and other similar models.
Clue 4: These parts are approx 50% hidden, 50% on show.
Clue 5: I would say that these parts hardly ever go wrong, or need repairing or replacing.
Clue 6: You use this part every time you use your Zuke
It's flippin' obvious now isn't it?
