Mikes lwb build and repairs !
Re: Mikes rotten Kja PROGRESS !!! :)
Post by ROBBIE » Wed Mar 18, 2015 9:20 am
Why you cutting the cab? And what way side to side or front to back?
timwilks13
SCUK Website Padawan
Post by timwilks13 » Wed Mar 18, 2015 10:18 am
ROBBIE wrote:Why you cutting the cab? And what way side to side or front to back?
Or top to bottom?!
Seriously though why do you need to cut the cab in half? If its for repair purposes it seems like a backwards step, but if its to see how many cutting disks it takes to cut a cab in half, then its the perfect way to find out.
Post by dan_2k_uk » Wed Mar 18, 2015 10:36 am
Or top to bottom?!
If its just floor and roof through the door area I reckon it will only take 4 if they are the really narrow good ones.
Post by andyrew » Wed Mar 18, 2015 7:14 pm
im going to guess its a case of removing the kja specific bit of the cab
(rear panel and roof down to scuttle top and grafting it onto the front/lower
floor pan of the white soft top. kjas have a return on the back panel
to cover where the standard floor pan bends up to meet the rear floor of
a normal sj. this bit is usually rotten or plated to buggery so cuting it off
is probably easiest. id drill the spot welds out from the scuttle area seem and
sawp the lot over then plug weld it back up.
Rhinoman
Post by Rhinoman » Wed Mar 18, 2015 8:56 pm
I'm sure a spot weld drill bit would do a better job of separating the panels although it would take longer. I do remember that Tim Pink cut his in half to extend the cab.
Post by mike harris » Wed Mar 18, 2015 10:34 pm
I'm cutting through the bottom of the pillars, along the bulkhead, over the tunnel
About 3 inches above the sills. Replacing the whole floors, tunnel and the bottom foot of the bulkhead.
Mike
Post by mike harris » Wed Mar 18, 2015 10:37 pm
Backwards step? I think repairing it all in one go is a massive leep forward personally !
All will become clear, I've got a mint samurai body why not use it?! :)
timwilks13
Post by timwilks13 » Wed Mar 18, 2015 10:37 pm
mike harris wrote:I'm cutting through the bottom of the pillars, along the bulkhead, over the tunnel
Mike
More than 4 discs then I recon dan.
Post by mike harris » Wed Mar 18, 2015 10:50 pm
Il use a recip saw, cut through both sides of the pillar at once
Post by ScottieJ » Thu Mar 19, 2015 11:13 pm
I think it was the wording that confused people....."chopping in half" sounds like you are either cutting it down the middle lengthways or sideways :lol:
