Page 13 of 42
Re: Project KJA
Posted: Sat Jun 02, 2012 8:39 am
by ROBBIE
I lost a bearing out of 1 of my hubs :oops: so took the other 1 to the local bike shop and got a bag of them for 99p :D
Re: Project KJA
Posted: Sun Jun 17, 2012 10:08 pm
by ianedwards
i found it while looking for something else i dropped, lol
few pics of what ive done. going to try and repair the tank, (wish me luck)
just got the brackets for the tank, finish the tail pipe off, and put the bracket fot the filler and its ready for paint, hoping to have her on her wheels by the end of the week. ;) maby lol
i did try putting the springs back under the axle today, but i tried it for size, no chance with them wheels, leaves about 2 inches of upward movement before the tyre would hit the bottom of the rear bed, so it will have to stay as it was which is a shame. a hour or so wasted
Ian
Re: Project KJA
Posted: Wed Jun 20, 2012 9:10 pm
by ianedwards
I think the petrol tank is officially more weld than tank now, and still leaking a bit lol Bit more welding is needed grrrrrrr
Ian
Re: Project KJA
Posted: Wed Jun 20, 2012 9:48 pm
by dan_2k_uk
Is the kja tank different in some way to a standard swb one?
It looks the same apart from the filler that could be adapted with a different hose.
If not I would just find a good spare. Hate trying to get a air tight weld. Maybe its just my skills!
Re: Project KJA
Posted: Thu Jun 21, 2012 10:40 am
by ianedwards
It's the joints around the tabs for the bolt holes on the middle rib, it's a pain.
The main problem was my dad started it lol , hes no welder - I'll say no more lol.
The difference is The filler comes out the side rather than the end. If I could find another tank I'd have just used a replacement, either moved the filler or turned The tank. The problem I had was trying to find a tank for the right price. The tank price plus traveling costs = the price of a new one.
And I need to crack on with the brackets on the chassis so I can Get her painted and rolling again.
So I'll give it a go, if no luck I'll have to look for another tank. I have confidence that if I weld the seams up a bit it should be ok.
Cheers Ian
Re: Project KJA
Posted: Sat Jun 23, 2012 9:47 pm
by ianedwards
Right, got the petrol tank sorted. After hrs of filling patching and some more welding.
Popped the cab on tonight, it revealed I need to make some minor adgustments to the exhaust. Cos it's touching the body. Not as much room there as i thought lol. It's gona be tight.
Lights ordered, so I can get on with fitting the brackets for them when they come.
I wanted to have it done this weekend but works been so busy I haven't been able to. Some time off is called for me thinks.
Ian
Re: Project KJA
Posted: Sun Jul 01, 2012 9:37 pm
by ianedwards
Good evening chaps,
A list of stuff sorted.
Exhaust finished properly for the second time, tank brackets finished,
bed cut to size - think ive found some old gates to use to finish it. I think they call it Recycling :brows:
Started doing the light boxes, there isn't enough room to do what I wanted so I've had to change my design.
Load of bits came in the post, spark plugs, oil filter, bolts, new nuts for the shackles. More bolts that I wrongly ordered, ie. I ordered new bolts for the top gear box holes. I looked at the size of holes in the gear box so I ordered m10, tried them tonight and the engine hole is m12. Oops £7 wasted. So shall have to order some more and open up the gearbox holes.
Decided to nick the tow hitch off the old mans disco, so got to get that off and mount that some how..
Got a bit to do but coming along nicely, forgot my phone tonight so I'll get some nice pics soon.
Ian
Re: Project KJA
Posted: Fri Jan 25, 2013 9:21 pm
by ianedwards
Hello chaps,
means i haven't been on here since July i thought id post an update on my progress,
ive spent a while looking at it, and not doing a lot to it, and not being able to update due to a knackered computer, but due to the sales, treated myself to a new laptop. but ive decided to stop looking at it and finish it.
any way ill let the pictures show my progress.
back coming together
bit more of back
bit more of back
light box things
light box things
rear + tow bar
rear + tow bar
rear + towbar + rear
rear mocked up
rear mocked up
rear mocked up
rear mocked up
rear mocked up
rear mocked up
wheel arch
wheel arch
chassis undercoated
chassis undercoated
chassis painted final coat
chassis
chassis
chassis
chassis
building the chassis up
building chassis up
building chassis up
building chassis up
building chassis up
More to follow
Ian
Re: Project KJA
Posted: Fri Jan 25, 2013 9:24 pm
by ianedwards
decided to go down the more rustic wooden sides due to them being cheaper to repair or replace if i give them a smack with something.
Ian
Re: Project KJA
Posted: Fri Jan 25, 2013 9:26 pm
by turbo-tom
Glad to have you back around fella! was wondering wear you been hiding recently!
looks like some real big progress has been made :thumbup:
and i like how you have hiden your rear winch looks really smart ;)
