Page 13 of 35
Re: Kiwizook's resto
Posted: Mon Aug 05, 2013 10:03 am
by kiwizook
the paint on that rocker cover is just etch primer, with a layer of deep black laquer over top. filed of the relief to get the effect. I'm pleased with it.
just decided to go the full engine rebuild while I'm at it. believe it or not, this is the first time I've ever taken an engine apart. I've dropped the piston's out, ready for a new set of piston rings and big end bearings when I've got the money. now need to do the piston rings, big end bearings, fit new water pump, clean block, paint block, replace core plugs, build up head, and fit it all back together with new gaskets, belts, hoses etc. Anyone know the whereabouts of a money tree?
Posted: Mon Aug 05, 2013 11:06 am
I heard a rumour there is a mystical money tree in Narnia.
Posted: Mon Aug 05, 2013 12:13 pm
by Edweird
Jordi wrote:I heard a rumour there is a mystical money tree in Narnia.
Lucky for Kiwizook he already lives there.
Posted: Wed Aug 07, 2013 11:07 am
by kiwizook
my new shocks arived today, but they are about a inch and a half longer than the original ones. Is this a problem, or is this fine?
- new and old
- Pic_0807_186.jpg (358.91 KiB) Viewed 5571 times
- the shocks
- Pic_0807_185.jpg (421.73 KiB) Viewed 5571 times
also started to rebuild my engine head. cleaned all parts in hot soapy water, and alligned them
- the clean parts
- Pic_0807_189.jpg (391.49 KiB) Viewed 5571 times
installed the valves on one side first, and then the other, and installed the cam before all that
- cam installed
- Pic_0807_190.jpg (469.03 KiB) Viewed 5571 times
- exaust side
- Pic_0807_191.jpg (384.01 KiB) Viewed 5571 times
- and intake side
- Pic_0807_192.jpg (389.56 KiB) Viewed 5571 times
found out those collets are a right pain in the arse, but got them all on in the end
feeling proud of this achievement, because I've never done anything like it before
hoping to get the rockers, springs and rocker shafts in tomorow. am waiting to earn more money too so I can buy piston rings, water pump and big ends. might as well go for the full rebuild while I got it apart
Posted: Wed Aug 07, 2013 11:38 am
by dan_2k_uk
The shocks wont be a problem as long as they are the same length when closed.
Posted: Wed Aug 07, 2013 11:44 am
by turbo-tom
Looks good buddy. Yep collets can be a pain in the arse at times!
Posted: Wed Aug 07, 2013 12:21 pm
Tidy work mate.
Posted: Wed Aug 07, 2013 12:43 pm
by Ladaman
I don't know if you was planning on "roughening up" or glaze busting the cylinder bores prior to fitting the new rings, but it is advisable. You don't really want to put new rings into "old" bores.
This link might help explain.
http://www.teglerizer.com/triumphstuff/ ... inders.htm
Or google glaze busting or cylinder honing.
Posted: Thu Aug 08, 2013 9:37 am
by kiwizook
Ladaman wrote:I don't know if you was planning on "roughening up" or glaze busting the cylinder bores prior to fitting the new rings, but it is advisable. You don't really want to put new rings into "old" bores.
A friend of mine used to be a mechanic, and he's got all the gear for it, and he offered to help me do it, so yes, I will be doing it.
got a little more done, got the rockers and shafts back on, with the new springs
Posted: Thu Aug 08, 2013 9:38 am
by kiwizook
just a question, does anyone know what the gaskets shown are for? I've got no clue
- mystery gaskets
- Pic_0808_194.jpg (427.98 KiB) Viewed 5544 times
