Can see it now, the uj looked one piece, I should have gone to sec saversAnton wrote:Yes. Also a "front UJ diff do-burry-whatsit", aka a front prop flange bolt head.zook123 wrote:Jimny Steering Bar?
Not sure if I should give it to you or to Darrell. I'll let you guys work it out between ya.
Anton wrote:Steering bar drag link...? Not sure if I'm using the correct terminology, but the bar that goes from the drag link to the pitman arm, is that the ball joint bit that drags the drag link bar?Darrell wrote:I'll just say it's from my GV and hope it's not too easy.
Something tells me it's not. But worth a shot.
Nope..
Track rod end?
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
zook123 wrote:Track rod end?
Nope.
Just a little bigger..
- Untitled hh.png (74.52 KiB) Viewed 20735 times
- donkeychomp
Your both on the right track
, but not correct.
turbo-tom wrote:Injector leak off bango?
nope.
