Page 15 of 22
Re: SJ410 -1985 'Cabrio', engine rebuild
Posted: Thu Sep 04, 2014 10:09 pm
by binge
Ref the vac advance, I think the only way I will get a vac at WOT is to take the vac from before the carb (I.E - Out of my snorkel). Is this right? I guess the standard airbox must have had a vac hose for the dizzy?
What's the crack with fuel pressure regulator then? Is that just a regular vac from manifold? My pressure reg has 2 take offs.
Posted: Fri Sep 05, 2014 8:58 am
by dan_2k_uk
Just one question. Where did you get the Suzuki ammo box?
Posted: Fri Sep 05, 2014 9:09 am
Looks like he got an ammo box and added as Suzuki badge
Posted: Fri Sep 05, 2014 9:46 am
by binge
Exactly that. Picked the ammo box up on a boot fair years ago, and the badge is the old one from the bonnet.
It's a handy box, as the pick up has no safe storage really, other than in the passenger footwell.
Posted: Sun Sep 07, 2014 10:01 pm
by binge
Posted: Sun Sep 07, 2014 10:12 pm
by donkeychomp
Barbie truck my arse....
Posted: Sun Sep 07, 2014 10:16 pm
by binge
Anything without a snorkel would of cut out to be fair, unless it has about a 10" lift!
It was just the drop into the water which submerged the entire engine.
Bobb took it real easy in his Vitara though, as it's his daily. Because I've got the Transit, I like to stick the SJ through it's paces. haha
Posted: Mon Sep 08, 2014 6:44 am
by kiwizook
did the engine take in any water?
Posted: Mon Sep 08, 2014 7:22 pm
by binge
I think it did, but only enough to cut it out, I.E, the first splash.
I didnt try to start it again until it had been dragged right out. Gave it a flick of the keys to make sure the bores were free, then fired it up. Went after a bit of cranking, and ran boggy for a few hours until the filter dried out.
Runs perfect again now. Really need this snorkel fitted before next outing. Will also be replacing the fan with a leccy one.
https://www.facebook.com/video.php?v=4677895362995
Posted: Mon Sep 08, 2014 10:11 pm
by binge
Just bought myself a universal radiator fan. Will get that fitted up with the snorkel, bit of marine grease around the electrics, and try that bomb hole again! :p
