Page 15 of 19
Re: 1991 Santana Samurai
Posted: Mon Oct 07, 2024 11:24 am
by tomcat
Interior panels in place. radio/CD/MP3 player yet to go in.
Sorting out bonnet hinges. All 4 No bolts loosen which is good news.
Posted: Tue Oct 08, 2024 5:21 am
by tomcat
Adding some additional rear flasher lights.
Posted: Thu Oct 17, 2024 10:27 am
by tomcat
As rear flasher lights were LED's needed to add in a resistor.
Area still needs tidying up but in position.
Posted: Sat Oct 19, 2024 9:24 am
by tomcat
Window regulators fitted both sides. From India but fitted well with soome TLC.
New weatherstrips on order. [Item 83811-80100]
Hardtop interior fitting on passenger side fitted.
Rear Fog lights fitted.
Good what you can do when it is dry!!
Posted: Sat Oct 19, 2024 3:38 pm
by tomcat
Rear Fog Light set-up.
Slight tweaking needed!!
Posted: Sun Oct 20, 2024 10:12 am
tomcat wrote: ↑Thu Oct 17, 2024 10:27 am
Just swap to a led flasher relay. There are under £10 on eBay. Just need to order one that is the correct polarity.
Posted: Tue Oct 22, 2024 9:56 am
by tomcat
[/quote]
[/quote]
All bulbs are non LED except for the 2 new rear side lamps. So I felt I only needed to add resistors to cover them. Is this not correct?
Posted: Tue Oct 22, 2024 8:11 pm
by Rankine
When I only had led fronts I didn't bother with resistors. But when I went full led, I did as scottie suggested.
Posted: Wed Oct 23, 2024 12:51 pm
tomcat wrote: ↑Tue Oct 22, 2024 9:56 am
[/quote]
[/quote]
You don’t actually need the resistors if they are additional lights as you still have the resistance from the factory bulbs for the flasher relay to work correctly. They are only
needed if your are replacing any of the original indicators with leds.
However it’s just easier to swap to a led flasher relay anyway, these still work with normal bulbs, they just don’t need the resistance from the bulbs to set the flash speed.
Posted: Tue Nov 26, 2024 4:52 pm
by tomcat
For all sorts of reasons work on "Sammy" has been very stop / start.
Got bonnet hinge area welded up and hinge itself free to move easily. Was well clogged up and took a lot of time to free-up properly.
Looking at headllights as originals were 45/40 watt. Plan on 60/55 w H4. Looked at a way of inserting a H4 bulb into the existing casing. Seemed a no go.
