Scottie's Zuke. Blue
- Lil_Beastie
Re: Scottie's Zuke
are you not putting a small UJ thingy where the spacer is just infront of the steering box (just mine has) or as youve fitted it at an angle it'll be alright?
Was:
Lil Beastie - 95 Sammie http://www.suzukiclubuk.co.uk/forum1/vi ... 22/t,3134/
Now:
Lil Monster - 86 VW Caddy http://rat-look.com/forum/viewtopic.php?f=10&t=8805
Now:
Re: Scottie's Zuke
Nah I'm just using the rag joint, with the wedge the shaft on the steering box is lined up with the steering column like the standard stering box is
- Can I have a tow
Re: Scottie's Zuke
some good progess your making there now,keep it up and you just might make it to kirton in augest
Re: Scottie's Zuke
Hopefully mateyparrotveasey81 wrote:some good progess your making there now,keep it up and you just might make it to kirton in augest
- Can I have a tow
Re: Scottie's Zuke
ScottieJ wrote:Hopefully mateyparrotveasey81 wrote:some good progess your making there now,keep it up and you just might make it to kirton in augestI'm going to be in the workshop every evening for a few hours from now on until it's finished
Re: Scottie's Zuke
ah Is that what you popped over for when I was at volksfest the other weekend? Karis couldn't remember what you said
yeah no worries!
Did you have that bush in the end? I think you should as I only have 3 of the large ones at home
I forgot to say I need 4 tubes for them
your a legend cheers matey!
- Can I have a tow
Re: Scottie's Zuke
ScottieJ wrote:ah Is that what you popped over for when I was at volksfest the other weekend? Karis couldn't remember what you saidyeah no worries!
Did you have that bush in the end? I think you should as I only have 3 of the large ones at homeI forgot to say I need 4 tubes for them
yes and yes,i will cut them tomorrow and drop them off in the tool room and see when they can do them
Re: Scottie's Zuke
Fawk yeah! nice one matey! that will mean the body can come off for the finalparrotveasey81 wrote:ScottieJ wrote:ah Is that what you popped over for when I was at volksfest the other weekend? Karis couldn't remember what you saidyeah no worries!
Re: Scottie's Zuke
i ran into a few issues tonight, i flxed it up to measure for my shock and upon closer inspection realised that my tyres were hitting the inner arch at the rear. I noticed the front did the other day but that just needs a bit of trimming
So i best get my ass in gear and rebuild my sammy axles pretty quickly
the extra width should sort the rubbing out.
some clearer pics of it flexed up
- Can I have a tow
Re: Scottie's Zuke
about time you fitted the wider axles but then the tyres will rub on the outer arch/footwell on the front and dont say they wont as they are close alread
