Kiwizook's resto
kiwizook
Re: Kiwizook's resto
Post by kiwizook » Wed Oct 16, 2013 8:30 am
got all these bits today ;) new transfer box mounts, transfer case lever boot, and new crank shaft bolt.
all the new bits and bobs
also had a look at the exhaust, and found this :argh:
one side...
one side...
... and the other
... and the other
I'll try to find a new splitter that fits, and weld in a new splitter. one more thing to add to the list :bawling:
kiwizook
Post by kiwizook » Fri Oct 18, 2013 5:02 am
so started with this
not so good
not so good
cut the broken bit out
cut the nastiness out
go these
shiny bits
shiny bits
and managed to do this
and made this :D
and made this :D
the welder wasn't going well, but after I had it set up right, I started over again, and I'm quite happy with it now. just have to join the two halves under the wagon now, and weld them together
dazerede
Post by dazerede » Fri Oct 18, 2013 7:19 am
That looks better all u have to do naw is fit the cherry bomb on the end and that will be sweet
4” calmini lift kit :)
kiwizook
Post by kiwizook » Fri Oct 18, 2013 10:17 am
I'll be keeping the standard muffler on it for now, as it has to go through a re-vinning process, and they might not like a cherry bomb on there. I will eventually put a straight through with a cherry bomb on it though, more noise than power :D
Post by turbo-tom » Fri Oct 18, 2013 10:28 pm
kiwizook wrote:more noise than power :D
More noise then you can shake a stick at.i like :D
dazerede
Post by dazerede » Fri Oct 18, 2013 11:30 pm
Haha I like that more noise than power
kiwizook
Post by kiwizook » Fri Oct 25, 2013 8:10 am
alright then. got monday off as it's labour weekend. I've just set the welder up with 0.6mm wire, got plenty of gas, weld through primer and sheetmetal. you all know what that means :brows:
Post by Jordi » Fri Oct 25, 2013 8:20 am
Your coming round mine to repair all my bodywork?
kiwizook
Post by kiwizook » Fri Oct 25, 2013 9:13 am
unfortunately that won't work in a single day, I could do if I had more days off :D
Post by Jordi » Fri Oct 25, 2013 9:28 am
Guess you must be plating, patching and welding yours then.
