Page 18 of 42
Re: Project KJA
Posted: Wed May 29, 2013 3:55 pm
by dan_2k_uk
Cant wait. Keep it up dude!
Re: Project KJA
Posted: Wed May 29, 2013 7:05 pm
by OllieSJ
This is the lid you were after
Re: Project KJA
Posted: Wed May 29, 2013 7:30 pm
by babakev
dan_2k_uk wrote:hi
looks like a bit of work uve got there.
regarding the body mounts. a couple of mine were stuck and a good ammount of wd40, lifting it up and down, jacking it up and down, and twisting the metal parts with a big set of mole grips did the trick.
let me know if you find some body mount rubbers. the only ones i could find with a quick search were from thailand and quite expensive.
Dan
I brought 2" Body mount rubbers on Ebay uk a few months ago for £8. & not got round to fitting them yet !
Re: Project KJA
Posted: Fri May 31, 2013 11:32 pm
by ianedwards
hi,
cheers but i managed to save the old ones, it was the metal dome things that had rotted so i made new ones and the tube inserts, rubbers will last a bit longer.
this is the lid thats broken, an inch holding it on lol
- lid
- IMG_0184.JPG (1.48 MiB) Viewed 5655 times
- lid
- IMG_0185.JPG (1.73 MiB) Viewed 5655 times
- front end, welded up and started painting
- IMG_1189.JPG (1.89 MiB) Viewed 5655 times
- inside painted, didnt do it all, just the bits that needed it
- IMG_1191.JPG (1.72 MiB) Viewed 5652 times
- just painted the bits ive worked on and that you will see, bit more to do on the rear floor
- IMG_1193.JPG (2.14 MiB) Viewed 5655 times
- inside of front end painted and all on and bolted up in its last resting place, just got to rub down and paint the out side and putting the new rad in
- IMG_0186.JPG (1.71 MiB) Viewed 5655 times
- IMG_0187.JPG (2.31 MiB) Viewed 5655 times
- its coming along
- IMG_0189.JPG (1.85 MiB) Viewed 5655 times
- new hawse and plate to cover my dads hole he cut
- IMG_0190.JPG (1.6 MiB) Viewed 5655 times
- and then comes the new winch rope for the rear winch, i liked the yellow one
- IMG_0182.JPG (1.46 MiB) Viewed 5655 times
- in process of cleaning and painting, need to find a badge or something to cover the old indicator holes
- IMG_1195.JPG (1.75 MiB) Viewed 5655 times
Hope you like,
Ian
Re: Project KJA
Posted: Fri May 31, 2013 11:40 pm
by OllieSJ
Good work. If you need the lid you know were i am
Re: Project KJA
Posted: Fri May 31, 2013 11:49 pm
by donkeychomp
Got these if you can use them...
Re: Project KJA
Posted: Fri May 31, 2013 11:55 pm
by ianedwards
Cheers, is it the same lid ? if it is ill have it off you.
Like the badges, shame it don't say 413. I'm thinking of putting a black and white Union Jack enamel badge Ive seen there.
Ian
Re: Project KJA
Posted: Sat Jun 01, 2013 12:01 am
by kiwizook
very nice work man. this is the standart I had in mind for my 410k a long time ago, has all gone out the window as I thought it was impossible, you might yet change my mind, as I see it is possible, but I'll have to upskill first
Re: Project KJA
Posted: Sat Jun 01, 2013 12:07 am
by OllieSJ
ianedwards wrote:Cheers, is it the same lid ? if it is ill have it off you.
Ian
yer only thing i have noticed is that as my dash is slightly faded the colour doesnt match any way its the same 99.9 % sure if not i will pay for postage back some how.
Re: Project KJA
Posted: Sat Jun 01, 2013 1:26 am
More tidy work Ian. Front end looks spot on.
Looling forward to seeing this on the road.
