Page 20 of 72
Re: the no dosh LJ revamp
Posted: Thu Feb 12, 2015 10:10 pm
by donkeychomp
No idea as yet. I will get the front wheels off and see what's what!
Posted: Fri Feb 13, 2015 10:50 am
by Rhinoman
The pad is worn out and, judging by the wear pattern, the disc is probably too thin as well. Combine the two and the pad falls out.
Posted: Fri Feb 13, 2015 11:30 am
by RickUK
That does not sound good,sounds like it could be a very expensive job but i doubt that it will
'brake' the bank
By finding that brake pad it could
'stop' your budget
'running' away with you.
Posted: Fri Feb 13, 2015 7:47 pm
by donkeychomp
lol
Going to do the lot, new discs pads shoes...if the pipes are dodgy new Goodridge ones too. The master cylinder is the bloody expensive thing but if it's nothing to do with that (and it looks like it isn't) I'll return it.
Posted: Tue Feb 17, 2015 8:23 pm
by donkeychomp
Piglet 5 now running just fine. Going to do some paint touch ups and she goes on ebay!
Posted: Tue Feb 17, 2015 11:06 pm
by Anton
A very fine beastie she is too!
Posted: Fri Feb 27, 2015 10:07 pm
by donkeychomp
Went to fit the new brakes today to Piglet 6. Discs...wrong. Pads...wrong. The discs were from ebay at £15 a pair...they will go back. The pads were from my local motor factor. Went back to him with the correct pad which had a Lucas part number on it so he ordered those and some new discs (£55 from him!). Many hours later the discs arrived...correct, and the pads...WRONG! Bangs head on brick wall...
Posted: Fri Feb 27, 2015 10:51 pm
by Anton
I can't quite tell from this angle, but that looks like a standard Aisin SJ calliper? Those pads should be 10-a-penny, well easy to get hold of!
The Jimny is still being fitted with those in the factory as we speak! I'm pretty sure some other Suzuki's (Alto?) come with them too.
Posted: Sat Feb 28, 2015 12:42 am
Yep they look like standard jap SJ discs and calipers to me. Just use my reg, d363 ccj.
Presume the vented discs in the box are the ones that are wrong, they look like GV discs.
Posted: Sat Feb 28, 2015 1:58 am
by donkeychomp
If all else fails I'll try your reg Scott, many thanks!
