Not striking up
Ladaman
Re: Not striking up
Post by Ladaman » Fri Sep 19, 2014 12:49 pm
When it backfires through the carb, that usually means the leads are 180 degrees out.
The compression results seem okay for a "normal" engine.
The Bird Man
Re: Not striking up
Post by The Bird Man » Fri Sep 19, 2014 1:29 pm
I'm really confused. Right I get it backfiring when the leads are in the opposite order right, when it backfires some sort of combustion is going on, the only things wrong is that it's not firing in the right order but when I put the leads in the correct order nothing. :S :er:
courior
Re: Not striking up
Post by courior » Fri Sep 19, 2014 1:47 pm
So maybe the leads are on backwards, and off a lot. Put the cap on 180 degrees backwards and while cranking slowly twist the dizzy as to adjust timing.. It might be so well off it still wont start when u turn the cap round?
Courior
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
The Bird Man
Re: Not striking up
Post by The Bird Man » Wed Oct 08, 2014 5:33 pm
Had a bit of time off with the engine and been focusing on the bodywork side of things recently, now that's almost complete I had another crack at trying to get her started today. Tried everything you guys suggested numerous times but still no avail :thumbdown: Any other ideas ? I'm running out. :|
Re: Not striking up
Post by twiss » Wed Oct 08, 2014 6:53 pm
Have you got a new timing belt on it now? Its worth replacing it as it will last a long time!
Sounds like a problem my mate had where the cam belt was 1 tooth out.
He managed to do it by revving the shit out of the engine!
Might be worth changing the belt if you haven't
when its on turn the engine by hand (I think its 4 times round??) and make sure the timing marks on the pulleys still line up?
Sorry if its something you've already done!
The Bird Man
Re: Not striking up
Post by The Bird Man » Wed Oct 08, 2014 7:40 pm
Admittedly I haven't yet, I wasn't going to spend any money on the engine until I know it runs as I'm a tight git :lol: Really 1 tooth ? I didn't think just 1 tooth out would make it not start, just run sluggish. Though as you can tell I'm no expert :D Last time I checked it I was pretty sure both sprockets all lined up alright but I shall have another check tomorrow :)
Re: Not striking up
Post by ScottieJ » Wed Oct 08, 2014 11:38 pm
If it was me it I would start from scratch with the timing, you can find the procedure here. It's the same for both the the 1.3 and 1.6, just make sure the cam is on the compression stroke before removing the belt, whip the no1 plug out, put your finger over the plug hole while you turn it over until you can feel pressure on your finger and then rotate it to TDC (when the marks line up)
http://forum.suzukiclubuk.co.uk/vi ... 608#p35608
Fit the belt and make sure the dizzy is pointing at number 1 or only just before.
The Bird Man
Re: Not striking up
Post by The Bird Man » Thu Oct 09, 2014 8:38 pm
Had a look at it today, when number one was at TDC on the compression stroke the rotor arm was pointing at number 4 on the dizzy cap so I popped it off and stuck it back on with it pointing to number one. At this point I was quite optimistic, cranked her over, unfortunately still no luck :roll: What on earth can be wrong. This is driving me berzerk !!!! Oh and thanks for your reply regarding the roof the other day Scottie ;)
The Bird Man
Re: Not striking up
Post by The Bird Man » Wed Oct 29, 2014 7:59 pm
Started a new job recently and got talking to this old boy who is apparently a wizz on engines, we got talking and told him what problems I'm having with my engine and he say's he guarantees the timing is out. He said to get number one piston and TDC on the compression stroke, if I do that the intake valve should be closed and the exhaust valve should be up ever so slightly from being closed. Now the only time I have this is when the timing marks on the sprockets and 90 degrees clockwise from the marks on the casing. I'm going to take the belt off and put this right but just in case I am wrong, is this engine an not interference engine ?
Re: Not striking up
Post by twiss » Thu Oct 30, 2014 12:40 am
No the 8v g series engines are non-interference
