Page 3 of 3
Re: A run of bad luck
Posted: Sun Nov 09, 2014 8:14 pm
Yeah, should sort the problem.
Just run spacers on the front to match the width.
His kit doesn't have oil seals either.
Posted: Sun Nov 09, 2014 10:34 pm
I've been running it without adding a seal for around 18months now, still on the same bearings that were fitted when I bought the axles off Tim pink, seams like a bit of gear oil actually helps them last.
Posted: Sun Nov 09, 2014 10:41 pm
by Ladaman
Are you using the Rob Storr full float rear set up Scottie?
I've just PM'd Mike H and he is, so it looks like that might be the way to go.
Posted: Sun Nov 09, 2014 10:54 pm
Yes I've been running it for 18months or so now, possibly longer?
Posted: Sun Nov 09, 2014 11:17 pm
by Ladaman
Just had a look through your build thread, and found it.
P53, so I can find it again, and it was 5th July 13 when you put pics up.
I think a call to Mr S in needed.
Posted: Mon Nov 10, 2014 12:52 am
by Anton
Jealous!
