Santana Pickup Build
rundo
Re: Santana Pickup Build
Post by rundo » Tue Jan 27, 2015 10:47 am
kiwizook wrote:you should be able to get it off with a wire brush on a drill or dremel. I just starting using por15 too, it's really expensive, but probably the greatest paint in existence! it'l do the job just fine on ali, without the need for primer or topcoat, and it's rock hard and chip free!
Not available in Bosnia :thumbdown: I am in lookout for substitute, there are some converter and 3in1 paints around. Will post what I have decided. While searching really could not find anybody on forum sports this hubs started to think it was aftermarket part? Even other SJ419 still got Aisin as standard. If anyone knows, picture is above, no marks on it except LOCK and FREE and made in USA between studs? Hubs are OK, work well its just for my future reference...
rundo
Post by rundo » Tue Apr 21, 2015 2:24 pm
These hubs are WARN 39198 like on american Tracker/Sidekick. I did what I have planned. Took them off, removed chipping paint, and sanded 800 then 1400 and alu polishing paste at the end. Did not go all the way with buffing though. Just to have decent shine. Will get stainless steel bolts later too
Post by donkeychomp » Wed Apr 22, 2015 1:53 am
What on earth is holding that wheel on? Are they plastic bolt covers?
rundo
Post by rundo » Wed Apr 22, 2015 2:44 pm
Yes, plastic covers packed with grease to keep water off threads and nuts...
Rhinoman
Post by Rhinoman » Thu Apr 23, 2015 7:05 pm
rundo wrote:These hubs are WARN 39198 like on american Tracker/Sidekick.
Yes that's correct, they were also fitted on later model Vitaras. I had them on my Vit from new until one broke, they have a plastic cam inside that is prone to breaking.
rundo
Post by rundo » Mon Apr 27, 2015 2:36 pm
Right, dont like plastic inside either... are they interchangeable with standard Aisins?
Rhinoman
Post by Rhinoman » Mon Apr 27, 2015 2:52 pm
Yes, there is no difference in bolt spacing or spline size.
rundo
Post by rundo » Thu Jun 18, 2015 8:59 am
Sun up - top down!
