Page 3 of 5
Re: Few questions on props and other bits
Posted: Mon Mar 21, 2016 6:04 pm
Cool, just wanted to make sure as it read as if you trailered it to a byway to use it.
You won't regret fitting samurai axles
Posted: Tue Mar 22, 2016 8:01 am
by Gilly_SJ
no as it was a bit poorly I though it may be a good idea to have some insurance against it breaking!
Picking the axles up Friday minus the diffs but Im lead to believe my 413 Diffs will fit in. Just need to work out how to fit them! I assume the half shafts will need to be removed partially to get the shafts in the splines on the diff?
Posted: Tue Mar 22, 2016 10:18 am
Yeah, pull your half shafts out and undo all the bolts around the diff. Half shafts can be pretty stubborn. Do it with the axle still in the Zuk on good ground sat on decent axle stands.
Might need a tap with a copper mallet just to break the seal with the housing.
Posted: Tue Mar 22, 2016 11:08 am
by Gilly_SJ
I tell you what I'd be lost without you lot! If we ever meet remind me to get the beers in!
Posted: Tue Mar 22, 2016 1:20 pm
If you have access to a slide hammer...use it to pull the rear shafts, it's the quickest and easiest thing to use.
Posted: Tue Mar 22, 2016 1:38 pm
by Gilly_SJ
Ill have summit kicking about.
Ive hit a snag with the brake lines on the rear ( easy was would be to remove them but thatll be thursday)
Part diagrams for a 413 say 300 ish mm long and m10x1 female both ends. The parts guy I use said the part number is showing a bit longer but m10x1 male both ends :S
Posted: Tue Mar 22, 2016 2:59 pm
by Anton
The copper pipes are male both ends, the two rubber flexie pipes that go from the chassis to the axle are both female both ends (or that's how mine were before I swapped in Samurai axles and went rear discs).
Posted: Tue Mar 22, 2016 3:08 pm
by Gilly_SJ
Yeah its the rubber ones I need to get made up longer.
I also kinked the steel ones to try and regain my front brakes but that didn't work so ill have to make them too :pissed:
literally owned this thing about 5 weeks now and its done 100 miles. I dread to think what I've spent on it. Snorkel came from euro4x4 so that's better news
Posted: Tue Mar 22, 2016 8:20 pm
by Anton
Gilly_SJ wrote:Yeah its the rubber ones I need to get made up longer.
http://www.llama4x4.com/page10.htm
I got Dave at Llama 4x4 to make me up braided ones...
As for what you've spent, don't think about it. I try not to think about what I've spent, if I did I'd just cry and cry... :P
Posted: Tue Mar 22, 2016 8:45 pm
by Gilly_SJ
I'm quite lucky we have a hydraulic hose place on the doorstep so hoping they will be cheap. 70 for a set is a bit steep however those llama ones are reasonable so cheers for the link!
I'm going to strip my brake lines/diffs Thursday and hopefully have it back on the sammy ones Friday!
