filling gearbox oil
Re: filling gearbox oil
Eeeerrrrrrrrr more than enough, think you need to drain some its 1.3L
too much oil is better than none i suppose.
although i bet someone will say its worse
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
It is worse, and the wrong oil is also bad,
A story.
Our JD6610, just serviced it and put universal oil all round. Next thing no drive in any gear. So rev it up flat out for 10 mins to get the vacume, next thing we have drive, but a horrible noise in between packs (6 boxes with 4 packs in each box)
Get the specialist out, using oil that is twice as thick, so i hope thats the problem because gear boxes aint cheap!
A story.
ah the oils the correct type, its what the motorfactors suggested and the same as the red bottle as shown earlier.
Anyhow its away to the mechanics tommorow. Its getting an engine oil change, sump and rocker gaskets replaced, the gearbox oil sorted, clutch set right and the coolant system looked at. It heated up rather rapidly i believe the the systems airlocked or the thermostat is defective. (but i have a supply of a spare rocker cover, sump, fuel pump, water pump, thermostat) so theres should be no problems.
is this the filler plug on the left?
No, its this one on the back of the gearbox. (Sometimes its a normal bolt instead of a square job.)
ah that explains why nothing come out, ill have a go at draining it.
thanks
thanks
- Edweird
I found that ratchet drives (1/2 inch etc.) usually fit in those pretty well. Is that what they're made for?
Yes they are made for the ratchet drives. Ive welded nuts to the end of mine as i HATE those stupid little square drive things, whats wrong with a simple bolt?
- Edweird
My brian is telling me that they're less likely to shear?
