Problem is it diff or prop shaft
Re: Problem is it diff or prop shaft
Chuck a load of WD40 on it as well
You will be able to get more leverage safer with a socket wrench
Dont snap it!
I done it called it a day after that so gunna drop gearbox in morning then should find the problem cheers for all the help so far
Good luck. Have you got a replacement clutch ready?
Dan
Dan
No i havnt was gunna try a few of my local car spares garages tomorrow
It's a massive, massive bolt they are quite resilient to damage!!!
Make sure you get the 3 part clutch kit. Theres no sense in not replacing the whole thing while you have it off..
I would phone motor factors today and order one... they never have them in stock really so it might take a day to get it in
Ok gerbox and clutch out clutch looks fooked to me but how would i no if anything is wrong with gearbox ? Id the clutch easy to reinstall ? Never done this before
If you give the gearbox a spin by hand with it in gear it should turn the output shaft where you took the transfer box prop from.
If that works then you are defo looking at a new clutch.
There is a handy video on centering one without an alignment tool on youtube.
I had never done it untill recently and got it spot on just by feeling round the edge the first try.
Dan
Dan
