MPG?
Re: MPG?
Post by Edweird » Thu Sep 27, 2012 8:18 pm
I wonder if your timing is out or something. I don't know what that'd do to fuel consumption but bad timing will make an engine run like a turd.
To me, it just sounds like your engine needs a tune up. Y'know, clean or replace your plugs, rebuild the carb, adjust the timing, adjust the mixture.
If you had it bits it'd only be a couple of hours work with a zook. Heck, if you lived near me I'd come round and do it for you.
james thomas
Re: MPG?
Post by james thomas » Thu Sep 27, 2012 8:35 pm
thanks edweird. prehaps i should sell some bits and take it to a garage. its got new plugs and air filter, il take the carb off and give it a clean and if that doesnt work il see if a garage can do anything. would the diffs be slowing it down?
Re: MPG?
Post by Tramp » Thu Sep 27, 2012 9:09 pm
Only if they are broke. generally speaking, diffs work or they go bang with very little in between. Setting the timing would be a good start, then I would change the filters (dont forget the fuel filter on the drivers side chassis leg) I would then change the sparkplugs, the leads & the rotor ARM & cap
Re: MPG?
Post by turbo-tom » Thu Sep 27, 2012 9:16 pm
mine is a weekend toy , so i forget about the mpg and just worry about the smile she puts on my face ;)
Re: MPG?
Post by Edweird » Thu Sep 27, 2012 11:03 pm
turbo-tom wrote:mine is a weekend toy , so i forget about the mpg and just worry about the smile she puts on my face ;)
You POOR fella! I get to smile every day! :doublethumbs:
Re: MPG?
Post by turbo-tom » Thu Sep 27, 2012 11:21 pm
haha i will when i can get the £6000 insurance! , atm though she is a trailer queen :P
james thomas
Re: MPG?
Post by james thomas » Sun Sep 30, 2012 8:16 am
i found a breather that should have been blocked off, so done that and now its running better/smoother. also filled he tank full and found a leak by the fuel filter..... lines look corroded so il change them today. ............ one last question, would a gearbox on its way out cause poor fuel consumption?
Re: MPG?
Post by dan_2k_uk » Sun Sep 30, 2012 8:22 am
Anything that adds resistance to the engine will increase fuel consumption.
Generally if something isnt functioning as its should do it will. Its like you are driving up hill all the time.
What kind of tyres do you have and what kind of pressure are you running?
Sounds like you might have found it tho.
Dan
james thomas
Re: MPG?
Post by james thomas » Sun Sep 30, 2012 10:21 am
its got 15inch rims with macho tyres, not too sure what exact, but theyr knobly ones for offroad. i put in 30 psi yesterday, but was told to run about 20psi. would you know what diamiter the fuel hose is?
Re: MPG?
Post by Edweird » Sun Sep 30, 2012 3:06 pm
james thomas wrote:its got 15inch rims with macho tyres, not too sure what exact, but theyr knobly ones for offroad. i put in 30 psi yesterday, but was told to run about 20psi. would you know what diamiter the fuel hose is?
Off the top of my head...I think I used 12mm for the fuel hose.
