Page 3 of 3
Re: Samurai SJ413 clutch swap UPDATED
Posted: Sun Aug 17, 2014 5:30 pm
Can do it with the gearbox in, just gotta slide it back.
Posted: Mon Aug 18, 2014 9:40 am
Its an easy side of the road job
Posted: Wed Aug 20, 2014 2:25 pm
by timwilks13
Just to clarify Jordi, which way round does the clutch go in? I can never remember and wouldnt want the ridicule of getting it wrong....
Posted: Wed Aug 20, 2014 2:35 pm
The flatter side of the clutch faces the flywheel... as it doesn't really fit the other way around
Posted: Wed Oct 08, 2014 6:23 pm
by Akseli
Ok, done the swap, i had to remove a bracket on the exhaustpipe and after that the gearbox went enough backwards so that i managed to swap the clutch disc and reinstall the clutch pakage back with a aligment tool.
If i`d been slightly wiser i`d would have drained the gearbox beforehand, the slipyoke fell off as i was removing the gearbox and started to drip oil on me
Posted: Wed Oct 08, 2014 6:54 pm
hahah thats a common occurence... there always have to be some oil involved
Trick is to tilt it forwards so it can't leak out!
Posted: Thu Oct 09, 2014 1:47 pm
by Akseli
twiss wrote:Trick is to tilt it forwards so it can't leak out!
I agree you on that, had the cars front tires on blocks and the rear tires on ground
Never the less, a valuable lesson was learned
Posted: Thu Oct 09, 2014 3:36 pm
When me and andyrew took a vitara engine out, I ended up covered in coolant and he ended up covered in transmission fluid!
The coolant sounds like the preferred option but he didn't have to drive 100+ miles home covered in it
(with an engine and gearbox wobbling about in the back i might add)
