starter motor...
Re: starter motor...
Post by turbo-tom » Wed May 22, 2013 10:48 pm
Well as I was lazy I slackend off the main starter motor bolts shuved in the airline blasted have of sussex mud out of of ot few squirts of brake n clutch cleaner another blast of the airline and bolted back together and boom shes a runner :D
Cheers chaps!:)
Post by turbo-tom » Fri May 31, 2013 10:22 pm
Well it lasted about 30 secs now removed the starter and going to strip it down so now I need to get a guide :)
Post by Darrell » Fri May 31, 2013 10:47 pm
I posted it up just as you got it going..............http://forum.suzukiclubuk.co.uk/vi ... =11&t=7586
Post by turbo-tom » Fri May 31, 2013 11:20 pm
Ahh see you do have a diagram!! Thank you very much! Will strip it down I think :)
Post by Jordi » Sat Jun 01, 2013 1:31 am
Almost got away with Tom.
Post by turbo-tom » Sat Jun 01, 2013 6:40 am
Yep but it pays for when you cut corners and dont work again :oops: :roll:
dunnin21
Post by dunnin21 » Sat Jun 01, 2013 8:18 am
had the same problem with mine a while back quick strip down a clean mended the problem
Post by turbo-tom » Sun Jun 02, 2013 8:07 pm
So cleaned and stripped today and bench tested all working fine now Its making the same noise again not even turning the engine over :pissed:
Post by ROBBIE » Mon Jun 03, 2013 9:54 am
Have you got a clicky starter fix in there? Mine did this last year and it was the relay that had gone
Post by turbo-tom » Mon Jun 03, 2013 10:31 am
Pretty sure I dont as I rewired most of my truck last year. All I have is the main wire from battery and the s post/ignition
