My new build
Pascal
Re: My new build
Post by Pascal » Fri Jul 19, 2013 2:01 pm
So now few changes, bigger winch! But now we must redo front to fit it properly. here is the work!
Hu weld on the front.jpg (120.33 KiB) Viewed 7343 times
Hu weld on the front 2.jpg (137.07 KiB) Viewed 7343 times
TIG detail.jpg (1.19 MiB) Viewed 7343 times
My guys fitting the original bumper.jpg (127.82 KiB) Viewed 7343 times
Pascal
Re: My new build
Post by Pascal » Sat Jul 20, 2013 2:36 pm
And finally is done! Mounted under the STD front bumper, tested, winched all days with it, put under the mud and so on.... Now sure i do will hang it from the roof of my factory! Will send you pictures! :smokin: :smokin:
Preping before pain job.jpg (141.69 KiB) Viewed 7334 times
And its painted.jpg (33.56 KiB) Viewed 7334 times
And all this fits under the STD front bumper.jpg (33.8 KiB) Viewed 7334 times
Mounting and wiring winch before the bumper mounting.jpg (106.35 KiB) Viewed 7334 times
From next week we start to work on new lift kit, 80mm plus brake system. (Final lift will be over 120mm!! This 80 mm is just development for guys that want it later!) At moment driving with 40 something (like 2 inch for imperial guys) and its flawless! Even at MAX speed (Around 150 KM/H) have no issues whatsoever. Taken even to the race track!! Installation is super easy and no other changes needed. Now for 80mm sure will be needed brake lines, relocation brackets to make it perfect, better sway bar (Anti rolling bar) to make it sitll capable on the roads and so on. Will see! Will keep you posted.
Uncle Pascal
Re: My new build
Post by Edweird » Sat Jul 20, 2013 2:57 pm
With the standard grill and bumper off, the Jimny looks a lot less cute and girly compared to normal. The bumper's easy enough to have an alternative one fabricated but a custom grill would be more difficult to make something that looks good.
Pascal
Re: My new build
Post by Pascal » Wed Jul 31, 2013 7:00 am
And here it is how looks at moment!
Now next steps, carbon fiber LED-Si roof lights! (Can work over 4 days just on battery!!), Super lightweight, massive lumen delivery, customized and possibel to have in few different sizes!
Then new engine setup, 1.6 bore, titanium coated side skirts, ceramic coated top lightewight foged pistons, Arrow Precision H-Beam connectin rods, Longer duration cams. All this to deliver more TORQUE, not really horse power. Target is on 950RPM to climb wihout having need to put accelerator! Means go over 40 degrees only on idle engine speed.
And last but not least solar panels and second electrcal system self sufficient for cooking, Air-Conditioner, refrigerator, plasma TV, PC and some LED-Si lights. ^_^
Considering tht is ALL done in the house, sure will need a week at least! So please look for updates in some week time. ^_^
My Jimny at moment.jpg (267.38 KiB) Viewed 7299 times
Re: My new build
Post by dan_2k_uk » Wed Jul 31, 2013 11:14 am
That winch looks brilliant poking through the bumper!
Re: My new build
Post by Edweird » Wed Jul 31, 2013 2:21 pm
This is a great build to watch. :D
Re: My new build
Post by turbo-tom » Wed Jul 31, 2013 2:24 pm
looks good. shame the tyre's let it down.
Re: My new build
Post by Edweird » Wed Jul 31, 2013 2:27 pm
turbo-tom wrote:looks good. shame the tyre's let it down.
Given the lift and spacers, I bet there's some wheels and tyres incoming.
windsor
Re: My new build
Post by windsor » Wed Jul 31, 2013 3:47 pm
Looking good
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
Pascal
Re: My new build
Post by Pascal » Tue Aug 06, 2013 6:04 pm
Tires are soon in! Just a bit busy lately with my work. Sorry guys! ^_^
