If you have a look in the service manual it will tell you the resistance of it at certain temperatures
You will need a multi meter and thermometer
Overheating
Re: Overheating
Re: Overheating
Ok thanks
Re: Overheating
Gonna run it into the garage today as I'm losing the plot with it now !!
Re: Overheating
So garage not really sure, got a new radiator cap and still no joy, going for a sniffer test on Friday. Any ideas on cost if it is the head gasget ????
Re: Overheating
Have had it all flushed through and a lower temp thermostat put in, all going ok, had the sniffer test done and there is a minute amount of signs of the head having a crack so gonna chuck in some steel seal and just keep my fingers crossed. Not losing loads of water anymore so happy with that !!
- Sj410red
Re: Overheating
Sounds good then, fingers crossed that is sorted now.
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Diff & Box high breather pipes
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
