Tims SJ410 Build Project
- timwilks13
- SCUK Website Padawan
Re: Tims SJ410 Build Project
My su no longer sticks out the top of the bonnet, the bonnet just needed making a little bit taller!
- IMG_20140227_191856146.jpg (757.71 KiB) Viewed 5993 times
- Edweird
Wow! That's neat. Nice job.
- timwilks13
partly why i photo graphed it from the back, its certainly not neat from the front!!Edweird wrote:Wow! That's neat. Nice job.
Pics of the front needed now thentimwilks13 wrote:partly why i photo graphed it from the back, its certainly not neat from the front!!Edweird wrote:Wow! That's neat. Nice job.
- timwilks13
Ok then its been ages since i update this thread, and quite a bit has gone into it since i last updated! To the point where im not sure where to even start explaining, also not sure the how the order of the images will appear so here goes.
Got some new 3" calmini springs for here, which meant extending the front hanger mounts slightly further forward as the fronts are longer than standard. This then caused my shock to foul on the bump stops at full flex, so had to cut and re-weld the shock mounts.
Going for some 31's to finished off my VL on the rear arches finally.
Also made up a couple of frames to plate the back tub off so half is solid and half is a hinged lid.
I have more pictures to add but i have just realised i dont have them all backed up on this computer. I will organise and upload the rest a bit later!
- IMG_20140209_184723213.jpg (962.66 KiB) Viewed 5882 times
- IMG_20140325_202729527.jpg (1.11 MiB) Viewed 5882 times
- IMG_20140327_224603453.jpg (792.5 KiB) Viewed 5882 times
- IMG_20140410_213349294.jpg (1.01 MiB) Viewed 5882 times
- IMG_20140421_220345192.jpg (1.21 MiB) Viewed 5882 times
- IMG_20140424_192434608.jpg (919.22 KiB) Viewed 5882 times
- IMG_20140423_222446566.jpg (1.02 MiB) Viewed 5882 times
- IMG_20140428_200333458.jpg (1.24 MiB) Viewed 5882 times
- Ladaman
- Suzuki Guru
Sweet
- timwilks13
Few more pics of things. Threw some 30mm spacers on too to miss the springs on full lock, and made myself a prop spacer to stop the front prop coming out, as it was only held in by about 3mm of splines.
Found somewhere for my furry dice too.
Still need to rob a bank then can get the correct carb spring and needle, and get some extended brake lines ordered. Ill flex it up later on my test ramp and lob up a picture.
- IMG_20140510_122153993.jpg (1.11 MiB) Viewed 5876 times
- IMG_20140513_203504581_HDR.jpg (999.93 KiB) Viewed 5876 times
- IMG_20140506_205542243.jpg (913.38 KiB) Viewed 5876 times
- IMG_20140507_184744862.jpg (1.02 MiB) Viewed 5876 times
Looking good
good work! really looks like a beast now, looks amazing
As said at Billing bud, looking really tidy now. As and when I've got time I'll try and get those doors to yours see if they're any good to you for half doors.
