Kiwizook's resto
Rhinoman
Re: Kiwizook's resto
Post by Rhinoman » Thu Apr 24, 2014 10:55 am
Yes, that one has had it.
kiwizook
Post by kiwizook » Sat May 24, 2014 1:48 am
so my fuel tank had several holes in it, and also several rust spots developing, and the liner someone put in it is all coming loose. so I bought another fuel tank, but unfortunately the fuel filler neck was on the wrong side, so I just glassed a new one in on the right side :D
Post by twiss » Sat May 24, 2014 7:54 pm
haha nice work!
kiwizook
Post by kiwizook » Wed May 28, 2014 8:50 am
just ordered a front axle rebuild kit, rubbers, felts,retainers, seals, kingpin bearings and wheel bearings, for equivelant of 50 quid, well happy with that! only need the kingpin bearings really, already has new felts and seals, but these'll be good for spares
kiwizook
Post by kiwizook » Sat May 31, 2014 6:15 am
I was going to get a big decal put on my bonnet, of a horse with the number 45 cut out, to represent the awesome performance of the f10a, 45 meaning the 45 bhp it has. but then I thought I might as well have a go at masking it off, and actually spraying it on, challenge accepted!
so I got some vinyl sheet at the local signfactory. this is the stuff they actually make decals out of. I'll draw my patern on this, stick it on my bonnet, cut out the shape, peel it off, leaving me with a perfect mask, the vinyl giving me a nice sharp line, as it doesn't leak like normal masking tape. should be doable.
I made this design, which I quite like. what's your thought's on it?
horse vinyl.png (69.87 KiB) Viewed 5850 times
edit: just got to sort out those front legs though :D
kiwizook
Post by kiwizook » Sat Jun 21, 2014 10:57 am
I've got 3 days off next week, and a big work shop I can use, so I am planning on finishing the welding then, finish the brakes, rebuild the front axle, and hopefully prep the cab for paint. might also have to replace the coils in my DD. I bough some new ones, but they were too short, so I'll have to sort that too
kiwizook
Post by kiwizook » Tue Jun 24, 2014 10:50 am
replaced the springs in my mazda, and fitted the cb too for good measure :D all set for tomorow, bring on the weldathon!
kiwizook
Post by kiwizook » Thu Jun 26, 2014 9:48 am
welded up the floor and bulkhead, patched a small hole in the roof, and started on the back of the cab, as it had 3 little strips off rust at the bottom. took out all the glass too, so I can get ready for painting it. one day to go, with the front wheel arches and the back of the cab to finish, so hopefully I will get it all finished
Rhinoman
Post by Rhinoman » Thu Jun 26, 2014 6:45 pm
Don't use fuel with ethanol in it or that mod will melt.
kiwizook
Post by kiwizook » Thu Jun 26, 2014 8:34 pm
good thing to know rhinoman, good thing my engine isn't some sort of high performance beast :D
