Scottie's Zuke. Blue
Re: Scottie's Zuke
Post by dan_2k_uk » Wed Sep 28, 2011 11:01 am
twiss wrote:I'll have you know I've spent the last 5 1/2 months trying to find someone to do my welding for free :P
Unsuccessfully I might add!
I did this for a year and a half
Its a very time consuming process in any build :hahaha:
Ended up bribing Scottie for a few lessons with Bacon Rolls, Pizza, and Beer tokens!
I did however get the welder for free.
Re: Scottie's Zuke
Post by twiss » Wed Sep 28, 2011 12:06 pm
Hahah i'm just gonna borrow my mates one!
I said he can come weld some bits for his vw camper in my garage if he keeps the welder at my house ;)
CoronaSrad
Re: Scottie's Zuke
Post by CoronaSrad » Sun Oct 02, 2011 8:45 pm
Just gone through the whole thread, 48 hours later and alot of pics im here! Great thread mate, Makes me want to keep mine and do some work to it just wish i had the money/time and knowledge to do all that! :)
K6 Gsxr 750.. Yoshimura R55 "Music To My Ears!" :)
Re: Scottie's Zuke
Post by ScottieJ » Mon Oct 03, 2011 1:18 pm
Cheers It's been a lot of work over the years and a long learning process!
Bit more progress! it's all a case of making stuff fit now, the old radiator mounts didn't work with the power steering and the old steering damper mount also had to come off as it was in the way of the PS pump.
Clearer pic of how tucked up the transmission is.
Started knocking up a new tank guard, I'm using the tube from the original one but adding some 3mm steel.
Re: Scottie's Zuke
Post by ScottieJ » Mon Oct 10, 2011 12:50 pm
Bit more progress
Here's how I set up my sammy axles for the conversion to 410 spring spacing and U-bolt eliminators
I set up my little jig using a 410 axle to space the box section to the correct width, tack the spring plates on to them and set the axle in the correct position and at the correct angle making sure the axle is centred an square with lots of careful measuring.
Tack on some plates on each side of the axle, check all the measurements again and weld up.
Cut out the main supports, tack them in, cut the tacks to remove axle form the jig and weld them up, allowing plenty of time for the axle to cool in between welds to avoid any axle warpage
Re: Scottie's Zuke
Post by ScottieJ » Fri Oct 21, 2011 12:26 pm
Rear Sammy axle is on and Check out my new wheels :lol:
Damn stock wheels look stupid with a virtual lift :hahaha:
I also modified my Gearbox shifter to make it a bit easier to finish the top cover of my transmission tunnel, I got my old boss to TIG it up for me :mrgreen: Just need to drill and tap it for a new breather.
Karis
Re: Scottie's Zuke
Post by Karis » Fri Oct 21, 2011 2:08 pm
ahahaha... ohh dear good job you have different tyres usually!
Karis
2000 Grand Vitara 2.5 V6 :)
Re: Scottie's Zuke
Post by ScottieJ » Sat Oct 22, 2011 8:50 pm
The sj has a new home :mrgreen:
Tomorrow ill be moving all my tools over to the new workshop
It does look quite sad on stock tyres
He's also got a bit of company
Re: Scottie's Zuke
Post by turbo-tom » Sat Oct 22, 2011 10:03 pm
would love a big work space like that :cowboy:: :lol:
Re: Scottie's Zuke
Post by ScottieJ » Fri Oct 28, 2011 12:44 pm
turbo-tom wrote:would love a big work space like that :cowboy:: :lol:
It is going to be good to not have to squeeze around the SJ to work on it.
Damn it looks good with the sammy axles and wide wheels :guns:
