Page 26 of 85
Re: Jordi's 1988 Samurai Build
Posted: Mon May 27, 2013 5:14 pm
Not much progress to report i'm afraid today. Jobs been stopped due to alternator issues. Main one being i don't have one that'll fit.
Radiator is almost sorted. Power steering pipes to sort, possible fab job with some copper pipes.
- image.jpg (2.37 MiB) Viewed 4294 times
- image.jpg (1.76 MiB) Viewed 4294 times
- image.jpg (1.72 MiB) Viewed 4294 times
See how quick i can get an alternator. (Or a pulley)
Posted: Mon May 27, 2013 6:00 pm
by OllieSJ
Looks good mate!
Posted: Mon May 27, 2013 6:11 pm
Well. Providing i can source some copper pipe and associated fittings, i think i'm gonna cut the banjos of both ends of my existing pipes and fit unions. Then flare the ends and make a custom fit copper pipe to run between the pump and the the PAS box.
I'm gonna sleep on that one. Think i've sourced my alternator though.
Posted: Mon May 27, 2013 6:55 pm
by Ladaman
Looking good fella, keep it up.
I'm glad to see I'm not on my own with little "challenges". They just test the grey cells, but you will get there. Some jobs aren't as easy as anticipated, but that will just give you a bigger sense of achievement when you succeed.
Keep up the good work, I'm sure you will be finished before me.
Posted: Mon May 27, 2013 6:59 pm
by Darrell
On the power steering high pressure side, don't you still need a rubber hose section to allow for engine movement/vibration.
Posted: Mon May 27, 2013 7:03 pm
Yeah. I have some small rubber sections with the machine made coupling at either end and then copper pipe sticking out. May utilise these to allow for movement.
Posted: Mon May 27, 2013 10:22 pm
Vit alternator arrived about half 8. Many thanks to Timwilks for collecting it from Pickering on his way down.
Posted: Mon May 27, 2013 11:01 pm
by turbo-tom
jordi your air filter..... what is that is it from a hair dryer or something?
Posted: Mon May 27, 2013 11:05 pm
turbo-tom wrote:jordi your air filter..... what is that is it from a hair dryer or something?
50mm steel Kawasaki bike filter. Does the job.
Posted: Mon May 27, 2013 11:06 pm
by turbo-tom
guess it dont restrict air flow does it?
