Page 30 of 32
Re: Ed's wagon
Posted: Thu Jan 16, 2014 10:14 pm
by Tramp
Ahh makes sense, if mine failed I'd do exactly the same! Tbh the light switch will be the culprit, take the door strap off then open it up so you can get in the hinge and remove the switch, clean the contacts with some emery paper and it will be fixed, my only other advice is do it before it's crushed, I imagine getting to the switch whilst the cars a cube might make the job a lot harder
Re: Ed's wagon
Posted: Thu Jan 16, 2014 10:20 pm
by andyrew
Edweird wrote:Bad news gentlemen. My Zook's courtesy light has stopped working when I open the door so I'm going to have to scrap my SJ.
They worked when they left the factory?!?
Well every days a school day.
Re: Ed's wagon
Posted: Thu Jan 16, 2014 11:01 pm
Strange, mine has decided to start working afters several years of not working.
Re: Ed's wagon
Posted: Thu Jan 16, 2014 11:14 pm
by Ladaman
What's one of those, you poser!
Re: Ed's wagon
Posted: Fri Jan 17, 2014 9:15 am
I haven't even got an interior light
Re: Ed's wagon
Posted: Fri Jan 17, 2014 12:54 pm
Switch + hammer = fixed!
Re: Ed's wagon
Posted: Sun Feb 16, 2014 11:53 pm
by Edweird
Nothing much going on but I thought folks might be pleased to hear that my SJ sailed through its MOT yesterday. Adjusted the carb a bit with the emissions tester in before they tested it. Went from 7.5% CO and about 700ppm of unburnt fuel to 1.6% CO and 195ppm (pass is less than 3.5% CO and 1200ppm).
What I have noticed is that as a result of the carb tuning then engine runs on a little bit sometimes when I turn off the ignition. I've got it sucking warm air because of the cold weather so I reckon that it's probably that plus it being relatively well tuned that is making it run on.
Re: Ed's wagon
Posted: Mon Feb 17, 2014 6:19 pm
by kiwizook
good stuff! congrats
Re: Ed's wagon
Posted: Mon Feb 17, 2014 9:00 pm
tune the engine back to how you like it, just keep note of the adjustment you make for MOT time
Re: Ed's wagon
Posted: Mon Feb 17, 2014 9:36 pm
by Rhinoman
Running on is usually a timing problem but it could be that you're running too lean.
