Dropped the gearbox and Transfer box off the bottom, along with all the props and shock absorbers too.
Quite pleasantly surprised that one of the 12 previous owners have undersealed it quite well. A few bits of underseal came away when I jacked it up high and jet washed underneath.
I'm in two minds whether to make a rad fit on the cage on the back, or fit the standard rad back under the bonnet.
We have endless radiators at work out of all different cars, so I'm very tempted to mount a nice big ally rad with an electric fan on it, in the back. Will have to work something out.
Sounds mad, but has anyone ever mounted a spare wheel under the bonnet, where the rad once was?
Is there enough upright room for it?
I've got a set of 4, Missing link shackles coming next week, so once they are here, I will work out the shocks I require front and rear.
I see a lot of these shock relocation brackets cropping up on FB. What is the advantage of this?
Will I need to weld some brackets on the axle too? Or does it just move the tops of the rear shocks further in?
Another question about suspension... I'm undecided on what to do with the 'lift'.
These missing link shackles will give me around a 1" lift as standard. Which will bring the truck back down by 1" compared to what it's like in the picture.
Should I do a 1" body lift? Is it worth it?
I really don't want it to be one of these trucks that are sky high on stilts. They just look like roll-over machines, and cartoon like, so a 2" lift, plus the 1" shackle lift, may put it up a bit too high.
In terms of the shackle lift, guy making them says they will give about 5" of 'droop'. What sort of prop spacers will I need?
Is there a way of measuring this?
