Page 4 of 4
Re: Santana seeking solution!
Posted: Tue Nov 25, 2014 8:33 pm
by Anton
I know a guy who ran a Hilux (which has a very similar drivetrain to ours) without the rear prop for months. You should be fine for a few hundred yards.
Posted: Tue Nov 25, 2014 10:39 pm
by donkeychomp
When my rear UJ exploded one night I drove home (15 miles) in FWD. And carried on for a week till I got a new one. No worries to drive it matey.
Posted: Sat Nov 29, 2014 3:26 pm
by rundo
This morning I have tried WD40 on UJs... runs smoother seems like UJs are dry so I will grease them tommorrow. Meanwhile, new video taken this morning...
https://www.youtube.com/watch?v=8h3htsIE5TU
Posted: Sun Jan 18, 2015 2:25 pm
by rundo
No post long time... been busy drinking around hollidays, if You drink dont drive, remember? Anyway, I read thru most of forum last week and find simple check rather than taking off rear driveshaft. I just flip Tbox to N and went thru gears... it was worst higher I go (bit shaking and horrible grinding noise in fifth). It was easy to pinpoint its resource and it was first UJ on first prop trans to Tbox. I hope that is it and it will be end of my problems. Also hope that its a cause and not the consequence... I will see that, planning to take this prop and rear for balance just to be sure that everything is in well... Happy new year to all!!!
Posted: Sun Jan 18, 2015 11:40 pm
by Anton
Hope that sorts it, mate!
Posted: Mon Jan 19, 2015 12:19 pm
Just to add, I would keep on top of those mid-prop UJs especially... My UJ snapped and the prop spun round, battered the shit out of the transmission tunnel, smashed the corner off the transfer box and ripped out about 2 foot of the wiring loom!
Posted: Mon Jan 19, 2015 12:27 pm
by Ladaman
twiss wrote:Just to add, I would keep on top of those mid-prop UJs especially... My UJ snapped and the prop spun round, battered the shit out of the transmission tunnel, smashed the corner off the transfer box and ripped out about 2 foot of the wiring loom!
Plus new underpants, a pair of jeans and a drivers seat.
Posted: Thu Jun 18, 2015 8:39 am
by rundo
Hi everyone,
decided to take off T-box one more time and re check it innards. While taking it off found that two of three mounts have actual bolt driven thru rubber so basicaly attached directly to cradle/chassis which I assumed made most of vibration. Also, countershaft had some serious surface damage (like bearings eaten it away). So I ended up replacing countershaft, both needle bearings and t-box gaskets (around 100 euro in parts pictured here).
Posted: Thu Jun 18, 2015 8:42 am
by rundo
For mounts I ordered Landy mounts from UK, it was faster to get, way cheaper and mounts are looking rugged and hard to tear...
Posted: Thu Jun 18, 2015 8:55 am
by rundo
Now I can tell that (most) vibrations gone, still got rattle and shift slack but after this I am pretty sure that it is rear diff need to be adjusted. I feel comfortable to drive it now this is most important will figure out diff solution down the road.
