Anyone near Bristol that can help?
Beardy89
Re: Anyone near Bristol that can help?
Post by Beardy89 » Sun May 17, 2015 5:55 am
Scott. Dont suppose you have a complete axle?
I need complete hub and stub axle as a minimum.
But thinking of doing rear disc conversion at some point so a complete axle with discs and calipers could be useful.
Post by ScottieJ » Mon May 18, 2015 12:45 pm
I should have all the bits you need, probably not much point buying a whole front axle though.
Beardy89
Post by Beardy89 » Mon May 18, 2015 12:54 pm
I only really need:
Hub
Stub Axle
Calipers
Caliper Mounts
Discs
(anything else needed to do a rear disc conversion)
If you've got the bits I've got cash waiting and can pop out to Corsham one evening this week...
Post by ScottieJ » Mon May 18, 2015 12:56 pm
will have to double check for callipers but I definitely have everything else.
Beardy89
Post by Beardy89 » Mon May 18, 2015 1:02 pm
ScottieJ wrote:will have to double check for callipers but I definitely have everything else.
Rear Disc conversion is only a nice to have at the moment so calipers not necessary at this stage.
To get it rolling I only need the Hub and Stub Axle, how many of my hard earned Great British Pounds would it take to get those from you?
Post by ScottieJ » Mon May 18, 2015 1:18 pm
Are you going to do the rear disc conversion how it's done in the DIY section on here?
Beardy89
Post by Beardy89 » Mon May 18, 2015 1:21 pm
ScottieJ wrote:Are you going to do the rear disc conversion how it's done in the DIY section on here?
I was going to as that's the only guide i've seen...
Post by ScottieJ » Mon May 18, 2015 1:56 pm
ok cool, I'll see what i have later and txt you over a price.
Beardy89
Post by Beardy89 » Mon May 18, 2015 1:57 pm
Perfect.
Need a drivers side front indicator if you have one as well. :D
Post by ScottieJ » Mon May 18, 2015 2:56 pm
Bumper or side repeater? When you come over you'll realise there's not much I don't have :lol:
